code 43???
Old Apr 13, 2009 | 08:42 AM
ls-rex's Avatar
Icon2 code 43???
i have an 88 crx dx with a 97 ls engine. this swap has been done for 6 months or so and been throwing this code since day one. i know it is a fuel supply code, i had to replace the fuel pump when i did the swap so it is not the pump itself... also new fuel filter so im not sure if maybe a line is kinked or sumthing. also the car idles really high when i start it, like 3500rpm, it runs like a champ tho and never really gave me any trouble. also i did idle the car all the way down, and got a new tps. any help would be awesome!!!!!!!!
Old Apr 13, 2009 | 11:38 AM
CRX=MC2's Avatar
Default Re: code 43???
Search cel codes again! make sure your reading the blinks right, post the code defenition, then maybe people will be more help.
Old Apr 14, 2009 | 02:11 PM
laidout21's Avatar
sounds like the idle might be a vacuum leak... check the back of the manifold where the fuel pressuer regulator's vacuum line goes to maintain stable fuel pressure... that might be your whole problem!
if not then check out the main oxygen sensor and make sure it's hooked up... because i'm pretty sure it would make you throw a 43 if it's faulty or if the heater for it is messed up... it happened to me once in a delsol.
Old Apr 16, 2009 | 08:33 AM
ls-rex's Avatar
im pretty sure its not a vacuum leak, when its running i sprayed sum carb cleaner in that area, and usually that would make it rev higher. and for the o2, mine is only 1 wire, there is no heater. it is definately code 43, fuel supply system.
Old Apr 17, 2009 | 08:17 AM
ls-rex's Avatar
anybody???
Old Apr 18, 2009 | 07:12 AM
ls-rex's Avatar
ttt
Old Apr 18, 2009 | 07:41 AM
crx_si-r's Avatar
i had this same code and changed out everything from, vacuum lines-fuel pump-press regulator-filter-injectors, and still no go. then i finally decided to swap out the entire dx (converted to mpfi) for a 91 si, when i got to the fuel pump connector uner the rear cargo box (crx) saw that i had a wire that was grounding out. finished swapping out the harness and no more light.
check all your wires back there make sure nothing is stripped and grounding out.
Old Apr 18, 2009 | 07:44 AM
northemt88's Avatar
had the same problem.i get code 43 since i run no o2,my rex runs like a champ
Old Apr 18, 2009 | 08:45 AM
ls-rex's Avatar
Well my main issue isnt actually the code, my cel doesnt even come on all the time. I should have titled this, high idle issue, but i was thinking the two were connected. My main issue is the high idle, like really high! It starts off bout 4k then as it warms up if im lucky itll get down to like 2k, but as soon as i drive it and go to stop it stays idled up to like 4k. My first thought was tps, but like i said, i replaced it. Also i had a first gen ls in the car before and never had this issue. When i put in the newer ls, i put on the old manifold and sensors. Im not sure if this has anything to do with the code 43 or not. Like i say i can live with the code but this idle issue has got to come to a head! Any help would be appreciated........
Old Apr 18, 2009 | 08:46 AM
ls-rex's Avatar
ttt
Old Apr 18, 2009 | 01:47 PM
northemt88's Avatar
i had a high idle issue so i just loosened mt throttle cable and that was my problem.
Old Apr 19, 2009 | 06:48 AM
northemt88's Avatar
hey whenever you can start your car and with your foot pull back on your throttle pedal.I would be like at 2500 rpm at a stop light pull on the pedal and it would go down to 1000 the moment i gave it gas it would jump right back to 2500
Old Apr 20, 2009 | 09:31 AM
ls-rex's Avatar
Yea, at this point my throttle cable is pretty loose, i also tried pulling back on the pedal that didnt work either. I really appreciate all the input tho, eventually we'll figure it out i hope.
Old Apr 20, 2009 | 09:32 AM
ls-rex's Avatar
ttt
Old Apr 20, 2009 | 03:01 PM
ls-rex's Avatar
ttt
Old Apr 20, 2009 | 03:24 PM
civic_jones's Avatar
code 43 is your fuel supply system
Old Apr 20, 2009 | 04:29 PM
ls-rex's Avatar
ttt
Old Apr 20, 2009 | 06:46 PM
ef8sleeper's Avatar
im having the same issue.
i currently have an ef with the obd1 conversion
after the conversion i had the check engine code.
i also get bogging from time to time when i get to 2500 rpm
i think it might be wiring.
im going to check the wiring under the back seat as i think the previous owner did a kill switch to the fuel pump.
im also gonna try the ecu as i am currently running a ls ecu with a d16a6
ill keep you posted with any findings
Old Apr 23, 2009 | 07:49 AM
ls-rex's Avatar
Much appreciated! ttt
Old Apr 23, 2009 | 08:16 PM
northemt88's Avatar
mine started doing that also,for me it was a bad cut on the wiring for the fuel pump.fixed it up and code went away
Old Apr 23, 2009 | 09:02 PM
ef8sleeper's Avatar
i trouble shot it to a loose vacuum hose leading to the map sensor. it was causing all kinds of funky codes first i was getting a code for the fuel pump and then i got a map sensor code.
when i fixed the leak at the manifold where the map sensor line hooks up it all went away.
i also changed my spark plugs but i cant verify that the helped the issue.
i know the op mentioned that he has a 97 in a crx so i dont know if fix will help him as the 97 has the throttle body mounted map sensor but its worth a shot.
mostly check the hoses at the manifold for vacuum leaks
g/l with your issue
Old Apr 26, 2009 | 07:52 AM
ls-rex's Avatar
I bought all new vac lines last week, but that doesnt mean the map isnt cracked or something. Maybe i can find a throttle body with that map sensor on it.
ls-rex's Avatar
ttt
JdmEG6559
Nov 7, 2012 05:47 PM
91 luder
Aug 28, 2012 04:16 PM
Cole D
Jul 10, 2003 08:25 PM
OBDI JEDI
May 7, 2003 05:06 PM
oO
Apr 10, 2003 07:03 AM
