speedo cable too short after swap?
Old Apr 13, 2009 | 08:36 AM
m_shake's Avatar
Default speedo cable too short after swap?
i have a 91 crx si and i just did a B18C1 swap using hasport mounts(efb2) with the hydro to cable conversion. the issue im having is that the speedo cable won't reach the pickup piont on the tranny. im using the stock d16a6 speedo gear in the tranny. is there a longer cable that i can get like from a da or something? thanks.
Old Apr 13, 2009 | 09:05 AM
89CivicHb1's Avatar
Default Re: speedo cable too short after swap?
you are supposed to use the da speedo cable it is longer then the stock one i had the same problem when i did my swap i had the cable i just forgot to put it in
Old Apr 13, 2009 | 09:10 AM
m_shake's Avatar
thanks dude!!! guess ill order up a da cable
Old Apr 13, 2009 | 09:52 AM
JScott3d's Avatar
I used the stock cable on my 89 with an ls. I do not know if it makes a difference but I used innovative mounts.
Yoonit1
Transmission & Drivetrain
Nov 30, 2013 04:14 AM
bigballing222
Feb 2, 2011 05:18 PM
trexb16
Apr 21, 2004 03:15 PM
Desperado
Feb 21, 2003 08:10 PM
