Crankshaft/ rod combo
Old Apr 13, 2009 | 04:45 AM
civic-r11's Avatar
Default Crankshaft/ rod combo
I have a gsr block that is bored out to 85mm with darton mid sleeves in it.. i am wanting to use a b18b crankshaft and eagle rods in the block.. i am wondering if i can do that.. or what are the things i am going to have to do.. to do that.. Can i even use the stock ls rods.. or i have to get custom rods.. or should i even do it.. The reason for doing this is to get more displacment out of the gsr block.. what displacment would this put me at?? thanks
Old Apr 13, 2009 | 01:54 PM
kingofbattle909's Avatar
Default Re: Crankshaft/ rod combo
wow...
i wouldnt use the stock rods if youve already sleeved the block.
flip through a few (hybrid) pages and there should b a "l/s vtec or vtec block ls crank" thread.
this might help also...GL!
http://zealautowerks.com/bseries.html
Old Apr 13, 2009 | 04:01 PM
civic-r11's Avatar
Originally Posted by kingofbattle909
wow...
i am not going to be using stock rods.. i have eagle rods.. already for a ls.. that is why i was seeing what i can do.. because i dont want to buy new gsr rods...
Old Apr 14, 2009 | 06:26 AM
per4mance's Avatar
The deck height on the two blocks are the same. I have ran LS cranks in GSR's many times. It will work. Its the best of both worlds. The GSr block with the B18/B20 stroke. This way you dont have to worry about oil lines, headgaskets, ETC.
NaIsGay
Mid-Atlantic (Sales)
15
Mar 3, 2009 02:12 PM
Topdawgg
Jan 5, 2006 06:32 PM
cornhusker
Oct 4, 2004 02:58 PM
turbosi03
May 25, 2004 02:02 PM
