are these speakers good?
Old Apr 12, 2009 | 10:40 PM
patrickstar's Avatar
Default are these speakers good?
so im thinking of getting new speakers cus i THINK i need new ones. the sound gets all staticy and ugly when the bass is bumped up even just a little. i dont think they are blown. well here are the specs of the speakers i have in my car. i've been trying to learn about how car audio works but could someone tell me how good these speakers are? i wanna get better ones that have good bass and clean sound.
KENWOOD KFC-S166
Speaker Woofers= 158 mm (6in.) Pearl Mica Cone Type 180g (6.5oz) Magnet
Tweeters = 35mm (1 3/8" in.) Balanced Dome Type
Peak Power = 130 watts
Frequency Response = 35Hz 22,000Hz
Sensitivity = 91 dB@ 1m
Impedence = 40hms
Net Weight w/ Grille = 1,460g (3.2lb)/pr
thanks guys
Old Apr 12, 2009 | 11:15 PM
tazeat's Avatar
Default Re: are these speakers good?
I would guess they are pretty good speakers, but sensitivity is a tad on the low side, but not bad at all.
They would probably shine if you have an external amplifier to power them. (See peak power of 130 watts, most head units don't put out 1/4 of that).
Although I think over any stock speaker they will be a huge improvement.
I didnt see any reviews or any place that sells it, looks like it is an outdated model:
http://www.carreview.com/cat/car-aud...4_1805crx.aspx
Old Apr 12, 2009 | 11:33 PM
hmm the guy that gave it a review on the site you gave me seemed to be pleased with them. ya i couldnt find anything else on them either. except some guy selling a set on ebay for 8.99! LOL. so i figured these were cheapo speakers. its hooked up to a kenwood kac-7295 amp. the only problem i have with them is that i cant play music with any bass or else it sounds all "poppy." just dont wanna waste money on new speakers if these speakers are good already. maybe its just wiring problems.
Old Apr 13, 2009 | 12:29 AM
tazeat's Avatar
Haha if you can get them for 8.99 I'd give them a shot and report back. Sounds like a good deal to me, I wouldn't pay over $50 for them, but hey $8.99, sure.
Old Apr 13, 2009 | 02:50 AM
lowlife9's Avatar
lol he probably wants 89.99. unless there something really wrong with them i would sray away it sounds to good to be true.
Old Apr 13, 2009 | 05:07 AM
Jturtle's Avatar
New User
lol no not to good to be true. just crappy speakers. I would save your money and get a decent component set. with the mid range and tweeter separate going into a cross-over. much cleaner sound!
Old Apr 13, 2009 | 09:32 AM
lol i might just get new speakers. what do you guys suggest for under $100? i was looking at these on best buy.
http://www.bestbuy.com/site/olspage....=1198286346957
what do you guys think?
Old Apr 13, 2009 | 09:47 AM
GetawayInMoscow's Avatar
See if you can find some Alpine Type-S 6x9's on ebay
Old Apr 13, 2009 | 09:59 AM
hmmm totally forgot about ebay. haha
i found these
http://cgi.ebay.com/ALPINE-SPS-609-6...3A1%7C294%3A50
http://cgi.ebay.com/ALPINE-SPS-69C3-...3A1%7C294%3A50
i heard infinity was a good brand too, am i right? saw these for cheap
http://cgi.ebay.com/INFINITY-REFEREN...3A1%7C294%3A50
any feedback would be great thanks guys.
Old Apr 13, 2009 | 05:05 PM
i think im set on getting some 5.25" alpine type r's. here's the specs:
Pair of Type-R 5.25" 2-way Speakers
Power Handling:
Peak: 270 watts per speaker
RMS: 90 watts per speaker
Impedance: 4 ohms
Hybrid layered-pulp woofer with rubber surround
1" swiveling silk ring-dome tweeter
New Shallow Mounting Designed to fit virtually any vehicle
Custom Mounting Adapter kit included
Frequency Response: 70 Hz-27 kHz
Sensitivity: 86 dB
Top Mount depth: 2-5/16"
they'll be hooked up to a 600w kenwood amp. is this combo going to work?
Old Apr 13, 2009 | 06:49 PM
Type R's will be good if they are going to be amped
Old Apr 13, 2009 | 07:51 PM
i bet it will. haha. i was just curious if my 600w amp will be too much or too little power for the type r's.
Old Apr 13, 2009 | 09:08 PM
civic_driver's Avatar
If the hole in the door is 6" you should get 6" speakers. The reason I'm saying this is because those type-Rs are 5.25" speakers and they won't fit the speaker holes on your doors.
If you run tiny speakers with a big amplifier (speaking in terms of power ratings) then you will damage the speakers.
The other thing, how many channels does your amplifier have? It's probably a subwoofer amplifier (it has a mono/single output) so the only way to make it work is if you put 7 or more speakers in series with each other but that's not a good idea generally. Your best bet is to buy an amplifier made to run midranges but you should buy both speakers and an amplifier to match each other. If you buy one before the other it will be harder to find a match for it (unless it's a popular item).
Also, we have to know the minimum impedance of your amplifier.
Old Apr 13, 2009 | 09:20 PM
hmm ur right. i ended up doing more research and the 5.25" would be too small. i plan on purchasing a pair of 6.5" ALPINE SPR-17C's.
i don't know the impedence or any other specs of my amplifier. i did some research and i couldn't find ANYTHING about this amp. i bought the car with it so i have nothing. its a kenwood kac-7295. all i know is that its a 600w 2-chanel bridgeable amp.
edit: damnit, i just measured the hole on my door and its 5.25". so i guess im going to have to get 5.25" then.
Old Apr 13, 2009 | 09:31 PM
The other option (if you want to have a speaker with a bigger diameter) is to cut the hole yourself. But if you don't want to be bothered you'll have to get 5.25" speakers.
Old Apr 13, 2009 | 09:40 PM
How many speakers are you going to power? 2 or 4?
According to this http://www.jeepforum.com/forum/showthread.php?t=173875 your amp is 150x2 so if you can find two speakers that are more than 150W RMS then you can use your amplifier to power two of those.
If you want to power 4 speakers you will have to get a 4 channel amplifier with an RMS rating that is lower than the speakers' RMS rating.
It's probably best if you use the amplifier you have to run a subwoofer in a bridged mode. Just have to find the minimum impedance on the amplifier and get a subwoofer with the same ratings (probably 4 ohms).
Old Apr 13, 2009 | 10:02 PM
well i will be powering 2 front speakers.
so basically, when pairing up speakers and an amp, the RMS rating for the speakers should be higher than the amp right?
so i can either use the amp to power speakers or power a sub, but not at the same time right? i don't plan on hooking up a sub anyways. just need so good speakers for now.
i was thinking, since the hole is 5.25", can i just get some speaker spacers and be able to fit 6.5" on em? i don't wanna end up hitting the window
Old Apr 14, 2009 | 01:12 AM
tazeat's Avatar
You can have either, you just have to match them right. If the amp puts out more power than the speaker can take, you just have to turn down the gains and not turn it up so that you overpower the speakers or they will blow or burn up or ruin them. If the amp doesn't have enough power when you turn it up you can clip the signal (ie a square wave) which will cause the speaker to overheat and hurt them. Really you rarely ever blow a speaker as long as you just don't go turning it up past where it sounds bad anyway, but technically you can ruin a speaker in both ways. As long as the numbers are close I wouldn't worry too much about ruining the speaker.
Old Apr 14, 2009 | 06:44 AM
thanks a lot tazeat and civic_driver! i have my choice set on some alpine type r's. now just need to figure out what size lol. i was talking about getting a spacer because i was thinking, if the hole in my door is 5.25 and i get 6.5's, could i use spacers so that only the magnet would go into the 5.25" hole. i hope you guys follow that. haha. if not ill be set on getting some 5.25"
Old Apr 14, 2009 | 08:22 AM
If you're using spacers you have to make sure that they're deep enough for the speakers. With spacers it might protrude too much and be a problem for you. It's best if you get the size of speakers for your car or make the hole larger to accommodate larger speakers.
Old Apr 14, 2009 | 01:22 PM
alright thanks for the help. i think the 6.5 speakers will bolt on, its just the depth of the speaker/magnet now. the alpine type r's state they have a shallower mounting depth so it might just do. the window is just so close, that's why i thought using spacers would be my only option.
bopbop93030
Audio / Security / Video
Apr 27, 2009 11:36 AM
froogle29
17
Oct 27, 2007 06:58 AM
'Accord Ex'
Aug 12, 2007 09:37 PM
General Kills
Nov 21, 2005 06:26 PM
orangegsr
Apr 20, 2004 09:41 AM
