need to identify a head
Old Apr 12, 2009 | 07:57 PM
mitchell_2kSiR's Avatar
Default need to identify a head
i have a cracked head on my number 3 cyl and my head code is pr3
is it true that the pr3 head not only came on my b16a motor, but they use it for the gsr too??
let me know becasue i need to buy one and i'm wondering if a b18 one will work
Old Apr 12, 2009 | 08:09 PM
91bluehatch's Avatar
Default Re: need to identify a head
That head is used on the b16's and the type r's use that same head with the exception of porting. The gsr uses a different head.
Old Apr 13, 2009 | 10:53 AM
Farmer89511's Avatar
yeah i believe a GSR is P-75 but b16 heads are Pr3-1, 3-2, 3-3, 3-4 depends on the year it was casted
Old Apr 13, 2009 | 02:00 PM
00Red_SiR's Avatar
All Motor Mentor
GSR is P72 and will work but require a different intake manifold than the one that fit your PR3 head.
Old Apr 13, 2009 | 03:04 PM
DB2-R81's Avatar
25 Year Member
Why is that all you experts forget 92/93 B17 GSR came with a PR3 Head?
Also the PR3-1, -2, -3, and -4 dash numbers have no correlation to the year cast, only the line they were produced on.
Old Apr 13, 2009 | 05:25 PM
really because all the older heads i have seen like 1992 to 1994 was like Pr3-1 or 3-2 and the b16 in the 1999 and 2000 si was like Pr3-3 and Pr 3-4
Old Apr 13, 2009 | 07:06 PM
00Red_SiR's Avatar
All Motor Mentor
You'll notice that there were no "experts" who commented on that part of the question.
as you can see...
Old Apr 14, 2009 | 01:47 PM
hey buddy i am just saying what i have seen...
Old Apr 15, 2009 | 01:47 AM
00Red_SiR's Avatar
All Motor Mentor
Maybe you are but that doesn't make it a fact and that's how misinformation gets spread.
Old Apr 15, 2009 | 06:55 AM
yeah that does make sence i did more searching and the casting numbers and the years have nothing to do with each other it has more to to with the port sizes and ITR and CTR has stronger springs and i think the 98 spec has something with the intake valves...
Old Apr 15, 2009 | 12:26 PM
00Red_SiR's Avatar
All Motor Mentor
The port sizes are all the same since they were all from the same PR3 head casting. None of those casting numbers were specific to the ITR/CTR head so you can't tell what the head was from by the PR3- whatever, casting number. Those numbers did not correlate to any specific valvetrain or cams either, it was strictly a head casting type only.
Old Apr 15, 2009 | 04:19 PM
oh okay i see they casted the head and then later down the line they would build it for like normal B16 or ITR or CTR head?...
Old Apr 15, 2009 | 04:32 PM
00Red_SiR's Avatar
All Motor Mentor
Yes, they just pulled a head from the production line and gave it some minor bowl cleanup and a valve job, then the valvetrain and it became a CTR/ITR head essentially. All the other heads were regular production for the B16a's and B17a's a long time ago.
Old Apr 15, 2009 | 04:34 PM
oh okay thanks for tell me this
ej93
Nov 11, 2010 12:02 PM
kc8enb
Aug 26, 2006 05:00 PM
1.8T_EG
Oct 21, 2002 08:53 AM
blackR#663
Aug 19, 2001 06:15 AM
