Ls/Vtec Turbo Build
Ok im starting my new ls/vtec turbo build. so far i got this:
*Gsr Head
*B18b1 Block
*Block Guard
*SRP Pistons
*Eagle Rods
*JE Piston Rings
*Rod Bearings
*Main Bearings
*Gsr Oil Pump
*Garrett Turbo
*FMI
*Intercooler Pipes
*Turbo Timer
*Fuel Pump
I'm about to buy what i'm missing:
*Gsr Water Pump
*Gsr Dizzy
*Gsr Arp Head Studs
*Fuel Injectors
*FPR
*Chipped ECU
*Turbo Log Manifold
*Downpipe
*Oil Feed And Return Lines
*BOV
*Wastegate
*Vacumm manifold
Is there anything else need to complete the setup?
*Gsr Head
*B18b1 Block
*Block Guard
*SRP Pistons
*Eagle Rods
*JE Piston Rings
*Rod Bearings
*Main Bearings
*Gsr Oil Pump
*Garrett Turbo
*FMI
*Intercooler Pipes
*Turbo Timer
*Fuel Pump
*Gsr Water Pump
*Gsr Dizzy
*Gsr Arp Head Studs
*Fuel Injectors
*FPR
*Chipped ECU
*Turbo Log Manifold
*Downpipe
*BOV
*Wastegate
*Vacumm manifold
Slacker93eg
Aug 19, 2017 02:06 PM
jdm4show
Sep 4, 2004 12:40 AM
