J's Racing Carbon Canard...
Old Aug 15, 2002 | 04:49 AM
Flux's Avatar
Default J's Racing Carbon Canard...
Will the J's Racing carbon canard fit a USDM ITR or do you have to have the JDM front conversion?
Old Aug 15, 2002 | 08:26 AM
555R's Avatar
Default Re: J's Racing Carbon Canard... (Flux)
the J's Canard will fit the EG EK and DC
same part number for all three
they dont fit completely flush but are damn close that it probably wont matter
Old Aug 15, 2002 | 08:27 AM
Chris N's Avatar
Default Re: J's Racing Carbon Canard... (555R)
Sorry for the dumb question: What is this Carbon Canard? I'm totally clueless.
Old Aug 15, 2002 | 08:41 AM
ryu12341's Avatar
Default Re: J's Racing Carbon Canard... (1107)
its fins on the front of the car that provide downforce
Old Aug 15, 2002 | 08:48 AM
Kengs's Avatar
Default Re: J's Racing Carbon Canard... (ryu12341)
I'm 99.9% sure the J's canards are made by First Molding/CRUX; they are actually available in 3 different sizes, so you can "stagger" them if you want.
http://www.firstmolding.com/firstmol...rd/canard.html
Old Aug 15, 2002 | 08:51 AM
Dee's Avatar
Dee
Default Re: J's Racing Carbon Canard... (kengs)
Most of J's Racing parts are rebadged First Molding/CRUX.
Old Aug 15, 2002 | 08:53 AM
Flux's Avatar
Default Re: J's Racing Carbon Canard... (Dee)
Can you get them cheaper by buying the First Molding/Crux parts instead of the J's Racing parts? Does anybody in the U.S. carry the First Molding/Crux parts?
Old Aug 15, 2002 | 09:44 AM
Casey's Avatar
can you actually feel a difference with the canards and winglets on the front of the car? i know mike at ips has them, and i believe n1-r did as well, any 1st hand experience? thanks
Old Aug 15, 2002 | 11:23 AM
rockwilda's Avatar
Default Re: J's Racing Carbon Canard... (CWTypeR463)
i believe Mike at IPS has the ARC splitters, unless he got more goodies.
here's a pic of mine...
this last one was when i test fitted it and you can see the masking tape
not sure if i can "feel" the J's canard working but i know my ARC splitters kind of pull my ITR lip down after driving. i can see the line between the lip and bumper when i get off the car and have to push it back up. *shrug*
Old Aug 15, 2002 | 11:26 AM
Tommy_Gunns's Avatar
Default Re: J's Racing Carbon Canard... (rockwilda)
This pic has me thinking. You could angle the ARC splitter (or any other splitter) towards the front wheels and use it to cool the brakes...what do you think?
Old Aug 15, 2002 | 11:27 AM
Spikey's Avatar
the J's Racing carbon canard for EK and DC are different. The EK one is smaller than the DC one. Also, the DC one is made for JDM front ends, so the fitment is not as good as the curvature doesn't follow the bumper's curvature as closely. Another problem in putting on any canard onto a USDM front end is the the corner lights. When we were test fitting the canards on USDM ITRs, it was almost impossible to not cover a bit of the corner light, which looks really weird.
the canards shouldn't be confused with the front ARC winglets.... the canards are the diagonal pieces along the side of the bumper where as the winglets are are little fins on the bottom of the lip.
there is a substantial difference with the canards. the increase in front downforce is extremely noticeable. the car feels more planted and stable. with the canards, the car does not bounce as much going over bumps at high speed as the suspension settles quicker. on corners, the increase in stability and traction is very noticeable, especially on bumpy roads. without the canards, on a bumpy corner, the car would feel light, not that grippy, and not turning in as the car seems to be bouncing around... but with the canards, it's opposite... loads of grip and stability and turn in response is sharper
Old Aug 15, 2002 | 11:40 AM
ryu12341's Avatar
Default Re: J's Racing Carbon Canard... (Spikey)
would the J's racing canard work on a mugen front bumper?
Old Aug 15, 2002 | 11:44 AM
rockwilda's Avatar
actually the fitmint on the USDM front end is pretty damn good. it curves around the front bumper nicely and the mounting points line up evenly against the bumper with VERY little covering the corner lamp. seeing the lamp isn't an issue at all.
Tommy_Gunns - never thought about the brake cooling idea. nice thought bro, but it's kind of hard to angle the ARC splitter to that degree with out it sticking from the front. customizing one would yield better fitment and the angle you want. afterall, its just plastic
Old Aug 15, 2002 | 12:33 PM
Flux's Avatar
That ARC splitter is so sweet. Are those the ARC winglets in the pic?
Old Aug 15, 2002 | 12:41 PM
TW00Si's Avatar
New User
Are these things universal? I would like to have a set on my prelude.
Old Aug 15, 2002 | 12:42 PM
Kengs's Avatar
Dammit Jonathan, look what you started...now there are two (2) more things to add to my shopping list
Rockwilda, sweet car man!
Old Aug 15, 2002 | 12:44 PM
Flux's Avatar
It just never stops....
Old Aug 15, 2002 | 12:48 PM
Kengs's Avatar
BTW, there may be a CHEAPER alternative; this company called Charge Speed in Osaka sells what looks like an ABS plastic version of the canard (+ an ARC type splitter):
http://www.chargespeed.com/english/c...nard-cup_e.htm
Old Aug 15, 2002 | 01:03 PM
hungsteR's Avatar
How much do these splitters and winglets run?
Old Aug 15, 2002 | 01:13 PM
Spikey's Avatar
rockwilda: the canards you have on are actually for EK... the JDM DC2 ones are much bigger... if you try to mount the canards at a higher angle, ie. 30-45 degrees, then you will have the fitment and corner light problem
TW00Si: the winglets are universal to a certain point... you could mount them on any car but it just depends how they will match... same with the canards
kengs: as you probably know, many people in Japan use plastic or aluminum canards as well, to reduce the cost.
We'll be getting a plastic canard made up pretty soon for those that are interested.
Old Aug 15, 2002 | 01:26 PM
rockwilda's Avatar
Flux - yes they are ARC winglets...afterall it does say ARC real big on the side
Hung - too damn much
Spikey - i bought them used from a buddy that put them on his EG so that i could cut down cost...if tahts possible . i didn't even know there was a difference in size.
Old Aug 15, 2002 | 01:31 PM
BlueR's Avatar
so does a company call Dforce...don't have a link tho...i saw it in the Hyper Rev mag leo sent me...
Old Aug 15, 2002 | 02:35 PM
Kelvin96GSR's Avatar
25 Year Member
Default Re: J's Racing Carbon Canard... (BlueR)
just out of curiosity can you feel the difference during daily driving?
or only when on the track?
Old Aug 15, 2002 | 02:39 PM
Kengs's Avatar
U mean the suckers that make the green ARC intake knockoffs
http://www.djac.co.jp/dforce/index.shtml
Old Aug 15, 2002 | 03:01 PM
_unknown_'s Avatar
I'm selling my ARC front splinters (winglets).
Check it out... https://honda-tech.com/zerothread?id=252298
[Modified by garth, 4:02 PM 8/15/2002]
