Help??? Gears grinding
Old Apr 11, 2009 | 05:46 PM
Integ808's Avatar
Default Help??? Gears grinding
Alright so for some reasong now, i have a real hard time putting my car into first gear and even second.
in order for put it into first i litterally have to shove that bad boy in.
and sometime it just starts to grind. idk whats the problem, i need help.
BTW, my car is a 96 LS
Old Apr 11, 2009 | 05:56 PM
subway's Avatar
Default Re: Help??? Gears grinding
Hmmm..check fluids first?
Old Apr 11, 2009 | 06:09 PM
Integ808's Avatar
i recently just change my fluids, ever since that it's been acting up acting up.
could low fluids in the trans be the problem
Old Apr 11, 2009 | 08:28 PM
sloK's Avatar
that could easily be the problem. parts that arent properly lubricated will easily wear out, especially metal parts.
what i would do, is add more fluid and see if it fixes your problem, but if it starts to whine or continue to grind i would either rebuild the tranny or repalce it. with the whining that means that your gears r worn, never a good thing, that could have easily been caused by imporper lubrication.
Old Apr 11, 2009 | 09:08 PM
OrangeTeggy's Avatar
I dont know if this is true or not. But ive heard that after changing your fluid is when you start having problems with the tranny
Old Apr 12, 2009 | 04:42 AM
Dogginator's Avatar
Daisy... Daisy...
Your clutch may not be disengaging totally. Is it easier to do with the engine off? Typical grinds are second and third gear on the upshift.
Old Apr 12, 2009 | 04:59 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I have never heard of that. My tranny has 276K original miles with no grinds whatsoever aside from user error, and I have changed the fluid several times over the years, usually every 25K miles or so. For the past 120K+ miles I've been using GM Synchromesh Friction Modified. Awesome stuff.
As for it being hard to shift, it sounds like what happens when a clutch disc spring or other piece of metal around the springs breaks off and gets lodged so that the clutch can't disengage all the way. My OEM clutch looked like that when I changed it at about 135K miles on the car.
Old Apr 12, 2009 | 11:35 AM
slaminsam's Avatar
Im pretty sure he is thinking about high mileage automatics that havent been serviced before.
Old Apr 12, 2009 | 01:05 PM
Integ808's Avatar
Alright so i checked all my fluids it's all good.
but after just playing around with the gears when the car was turned off
it, seems to be all good, real easy to put into gears now.
Old Apr 12, 2009 | 02:37 PM
Community Builder
hm damn I hope that's not the case. My wife's car has 206K on it and it's automatic, and I have no clue when the last time the tranny was serviced.
Old Apr 12, 2009 | 04:59 PM
yunghov's Avatar
check the slave cylinder. is it wet. have it checked out. one night my clutch on my gsr just all of a sudden got really soft on the way home. i thought my clutch went but wen i checked it out it was only a slave cylinder. a couple dollars and 20 mins diy it was all good. good luck
Old Apr 12, 2009 | 05:36 PM
Blackout.'s Avatar
does it slip out at all? or you just have trouble getting her in?
Old Apr 12, 2009 | 08:37 PM
92integraVTECgsr's Avatar
I'm having this same problem with this 90 miata I just bought. Test drove the car, everything was perfect. Changed the trans fluid, now it will barely go into 2nd gear. It doesn't grind, it just won't go in. I don't want to force it and make things worse because it was fine before I changed the oil. I have a feeling the person I bought it from was using either GM or Penzoil Synchromesh. I am going to drain the fluid again and fill it up with one bottle of Penzoil Synchromesh and 1 bottle 75w-90 which it calls for and see what happens.
I've heard good things about the synchromesh. When I change my fluid in my ITR trans, I am going to try the same thing.
Old Apr 12, 2009 | 10:28 PM
CompanyFlow's Avatar
Why would changing your fluid give you problems in any car?
Old Apr 13, 2009 | 04:56 AM
slaminsam's Avatar
In an Automatic alot of times if you wait til mileage is extremely high to change it; the new fluid will cause enough friction to finish off the clutches in the clutch pack causing slippage. Mostly my experience with this has come from domestic automatics.
Old Apr 19, 2009 | 04:31 PM
dacrazyrican1's Avatar
^^^hilarious signature. But staying on topic, im having a similar issue so the stuff written in this thread is helpful info. I think my clutch is either worn or isnt disengaging completely. The problem seems intermittent and if i try to step on it, it seems harder to engage the next gear as opposed to just cruising and economy shifting. I just recently bought the car not even a month ago. Its an ls integra and its even still on temp tags.
Old Apr 19, 2009 | 04:51 PM
bluestd's Avatar
could be your clutch is f'ing up i had the same problem with my integra took the clutch out and that thing was gone put a new one in and shift like butter
Old Apr 19, 2009 | 09:16 PM
JonMaltese/LScivic's Avatar
check if your clutch master cylinder is leaking or if u even have fluid in the clutch resevoir
Old Apr 19, 2009 | 09:18 PM
go under your dash and follow the clutch pedal till u see a cylinder.... put your hand around it see if theres any oil..
Old Apr 19, 2009 | 11:03 PM
wunfstgsr's Avatar
Loved
Community Favorite
$5 on a broken clutch spring!
Old Apr 19, 2009 | 11:07 PM
TOO MUCH TORQUE's Avatar
yup, high mileage autos that had very few fluid changes should be left alone, however manual is ok. op did you put in the RIGHT type of fluid?
Old Apr 19, 2009 | 11:12 PM
SquirtleSquadEf9's Avatar
maybe they just didnt put enough oil in lol!!!
Old Apr 21, 2009 | 05:06 PM
Im assuming all the comments posted between this post and my last one are directed towards me as well as the original poster so tomorrow im goin to check all this stuff out. thanks for the help and anything that could potentially help me solve this crappy situation.
silov3r
Transmission & Drivetrain
Apr 22, 2013 06:36 AM
wallawee
Jul 21, 2007 03:57 AM
rdssk8rcs1
Oct 17, 2006 11:38 AM
silverboost
Feb 23, 2006 10:58 AM
94thundergrey
Sep 11, 2002 04:50 PM
