EF and b series parts for sale
Old Apr 11, 2009 | 03:12 PM
aasarsak's Avatar
Default EF and b series parts for sale
All body parts are from an 89 hatch. Don't ask me if they will fit anything else because I don't know.
1 x front bumper (cut out middle part to make way for intercooler) $15
2 x rear bumpers (one is perfect, the other has a crack on the passenger side) $25 and $15 respectively
1 x front bumper filler (dented on driver's side) - $10
2 x rear bumper filler (1 perfect, other is bent/denter on passenger side) $10 and $5 respectively
1 x set of rear bumper foam thingys - free with the purchase of rear bumper
OEM front brake system (calipers, rotors (drilled and slotted), lines, pads (90%), bracket, and all nuts, bolts and washers) - $100
1 x passenger clear corner (black) $5
1 x NIB kingston DDR2 1GB PC2-6400 notebook ram $15
B16A short block complete - make offer
B18B short block complete - make offer
B16A injectors - make offer
2.5" crush bend cat-back exhaust with fart can muffler - $50
more to come.
Old Apr 11, 2009 | 06:41 PM
aasarsak's Avatar
Default Re: EF and b series parts for sale
Here is the WTB part:
1 set (passenger and driver side) door panels for 89 civic hatch.
1 set forged 80mm 9:1 pistons (used) don't need the used rings
1 set of forged B16 rods (used)
1 set B16 valvetrain (used) titanium, high performance i.e. S2, supertech, etc.
1 used B16/ITR intake manifold high performance (not OEM) like S2, blox, etc.
1 89 civic hatchback carpet black (no tears, stains)
1 AC unit for EF with B16 (bracket, compressor, condensor, pipes and wiring)
Old Apr 11, 2009 | 07:19 PM
Eli2's Avatar
Bump for viewing!
Eli
Old Apr 11, 2009 | 08:52 PM
Unseen Racer's Avatar
bump cuz i looked
aasarsak's Avatar
Thanks Eli
Bump for your 420th post! blaze it up! LOL (I don't smoke, but I thout it would be funny)
some shots of the stuff for sale
bumper definitely needs paint, and some new grill mesh. Don't get it from auto zone (that's what is in there now) It just started coming apart at one of the seams for no reason...
I think the turn signal lights alone are worth more than I'm asking for the entire bumper...
Old Apr 12, 2009 | 01:12 PM
aftermath1312's Avatar
bump for you...
Old Apr 12, 2009 | 01:33 PM
Eli2's Avatar
Lol yea Bump for my post whoring lol.
Eli
Old Apr 12, 2009 | 04:10 PM
Eli2's Avatar
Wait did I say that out loud!? Woops well Bump for Easter!
Eli
Old Apr 12, 2009 | 07:39 PM
Old Apr 13, 2009 | 11:01 AM
no more bumping for you...lol
Old Apr 13, 2009 | 11:47 AM
Eli2's Avatar
Lol awww
Old Apr 14, 2009 | 11:44 AM
okay okay..another bump for you...
Old Apr 14, 2009 | 11:11 PM
pine_apple45's Avatar
ttt!!!
Old Apr 15, 2009 | 12:23 AM
Old Apr 15, 2009 | 07:41 AM
efjones9's Avatar
bumped for looking.I still wana get that bumper filler!!
pm'd u
Old Apr 15, 2009 | 03:46 PM
Old Apr 15, 2009 | 06:18 PM
Eli2's Avatar
BUMP!!
Eli
Old Apr 16, 2009 | 08:45 AM
kiddsohc's Avatar
what color is the bumber??
email me!!!
yohhe19@aol.com
Old Apr 16, 2009 | 11:08 AM
aasarsak's Avatar
pm replied -pending sale of bumper filler-
More pics
Old Apr 16, 2009 | 09:47 PM
up up ttt
Old Apr 17, 2009 | 07:58 AM
Old Apr 17, 2009 | 08:12 PM
[QUOTE=aasarsak;38132635]All body parts are from an 89 hatch. Don't ask me if they will fit anything else because I don't know.
do you know if the parts will fit a 91 hatch...
Old Apr 17, 2009 | 09:37 PM
aasarsak's Avatar
Yes. They will fit in your 91 inch *** hatch
some more pics
one of these rear bumper fillers is dented on both sides, but the other one is perfect. Just needs to be repainted, but will look decent as is.
One of my rear bumpers has a crack all the way down the passenger side
Old Apr 17, 2009 | 10:40 PM
aasarsak's Avatar
The same rear bumper that has a crack down the passenger side also looks like the driver side is cracked, but it's actually just the paint that's cracked. If you sand it all off, it is smooth underneath.
complete stock EF front brakes including lines. don't worry about the rust. You can have auto zone turn them for like $10 each.
Oh, BTW, that master cylinder is off a DA. I thought it would bolt in to my EF booster, but I'm here to tell you it doesn't. The bolts are in opposite directions. I would have to switch to a DA booster, and I don't feel like taking those pesky bolts out from behind the firewall. It's too damn tight up there... ( my excuse for being lazy)
Old Apr 17, 2009 | 10:48 PM
aasarsak's Avatar
a couple more shots of the Honda "truck motor" LOL
*disclaimer* I bought this block off a guy that told me it worked perfectly in his car. I also bought a tranny off this same guy who also said the tranny worked perfectly in his car, but somehow, when i put it in my car, it grinded in 3rd gear and made a really wierd clicking noise in reverse.
I never used it because I bought the block before I read about all the horror stories of guys boosing their B20s and ending up with cracked sleeves, so I decided to stick with my B16.
As you can see, it's been sitting in my back yard for about 6 months. I just keep it covered with plastic bags to keep as much moisture out as possible.
IMO, muuuuuuch easier to tell if a block is no good because you can visually see everything. Trannys are a little more mysterious to me because after popping the bell housing off them, I get lost in all the gears. I have no idea what to look for. A block however is a little easier. Just take it to a machine shop, and have its clearances checked. Much cheaper...
