dizzy wiring question
Old Apr 11, 2009 | 02:38 PM
ryanevansoh's Avatar
Default dizzy wiring question
ok on the mpfi swap it says to "connect" the c1 wire to the green blue on dizzy, and c2 to the blue yellow wire on the dizzy. when they say "connect" do i solder the wires together, or can i plug them up through the dizzy connector with pins? need help to finish swap, thanks
Old Apr 11, 2009 | 03:13 PM
Default Re: dizzy wiring question
come on, someone here must know how to finsih my mpfi swap
Old Apr 11, 2009 | 03:34 PM
efjones9's Avatar
u would have to solder it. the cleanest way to run the wires are thru the actual engine harness
Old Apr 11, 2009 | 03:39 PM
ok so i was thinking, could i use a pin and connect it to the plug to the correct pin on the dizzy plug. or do i solder just seperately?
OhShift!
Oct 5, 2012 05:32 PM
f20bcl
Jul 23, 2010 07:55 AM
thatHEMIguy
Mar 4, 2010 08:57 AM
C_R_X_V_T_E_C
12
Mar 20, 2007 01:06 PM
paybac4223
Mar 19, 2003 11:00 AM
