97 civic seats neoprene foam??
Old Apr 11, 2009 | 02:19 PM
b18c1eg2's Avatar
Default 97 civic seats neoprene foam??
Hello I was wondering what kind of foam material the 97 civic seats made out of and do you know if there treated with mildue (sp) n odor resistant cause i have a set of civic seats i plan on ripping apart to use as insulation in my hatch.. thanks for the help
Old Apr 12, 2009 | 12:08 PM
fcm's Avatar
fcm
Old Fart
Default Re: 97 civic seats neoprene foam??
Foam, [unless closed cell] should not be used as insulation as it will retain moisture.
What, exactly, is it you want to "insulate"? 94
Old Apr 12, 2009 | 02:11 PM
b18c1eg2's Avatar
I wanted to insulate the rear quarter panel... I was just wondering if they treated with some type of chemical to protect it from water and moisture, if not imma go for some type of protection to spray on and use it to insulate the rear quarter panel where the panel is hollow
thanks
Old Apr 13, 2009 | 06:22 AM
fcm's Avatar
fcm
Old Fart
That is not a good idea, anything like that will keep moisture up against the sheet metal and rusting will become a real problem. 94
bradmartinfl
Jul 6, 2010 08:24 AM
JMcDB18C
Sep 23, 2008 01:20 PM
johnqt3
May 16, 2006 04:05 PM
homeskillet
Nov 28, 2004 09:57 PM
