will a p06 ecu run my swap?
i got a 91 crx dx with a swapped b18a1 with an obd1 flip harness it runs a obd1 dizzy and obd1 injectors to elminate resistor box. will my swap run on a p06 ecu??
imo if you put in an ls motor try to get the harness from an obd0 ls you can rewire the injectors to be obd1 so you dont need the res. boxand run an obd0 dizzy it makes it much easier
im sure that your b16 would run alot better on a proper tune like a p30,
i run MY b16 on a p28, but its chipped. you can have the p06 chipped for a stock LS tune, and this guy does it all day, he did my p28 for me.
www.wickedinnovation.net
If you just need to fire it up and maybe drive it easily to a shop, the P06 will do
racingant
Jul 16, 2005 09:03 PM
