d16 and i have a gas smell in my oil????
hey i just checked my oil and it freakin smells like gas what could that be and why, i just changed it last week? no cel or nothing just have the smell and it seems to run the same but does have a little bit of white exhaust smoke??? please help me this kind of scares me just noticed last night...
Could be head gasket. Does your car overheat? Its normal for oil to have a slight smell of gasoline. How much is a bit of white smoke? You can buy a head gasket tester. It sucks coolant from the radiator into a tube that has a blue fluid in it. If there is exhaust gas's in the coolant the fluid turns yellow. Or you can do a leakdown/compression test.
But there is a few other things it could be. A cracked head, hairline crack in the block. The only way to know is to test, test, and retest.
Is the CEL ON? Do you smell unburnt gas in the exhaust (=running rich)? Usually, this will cause black exhaust smoke. Check whether one of the injectors is stuck open. You also might want to check the fuel pressure.
no there is no cel and i just had it tuned because it was running rich, should i change my oil again because i run royal purple and that **** aint cheap and i just changed it like seriously last week on the 6th and how would i check to see if an injector is stuck open?
i mean it was tuned at a abel racing with an apexi neo so it isnt like a true tune that is done with the computer chip and stuff......yet
Discard the running rich idea for now. Did you recently have trouble starting the engine? This may have caused engine flooding and therefore the gas smell in the oil. The only remedy is to drain and refill if the odor is actually gasoline.
no i have not do you think i should just go on a long like 30 to 45 minute drive of just non stop driving to see if that works then come home and check my oil and stuff and see what happens or what? because i have heard of someone saying to try that before
Are you the guy who made less power than the stock y8 even though you have a lot of mods to your engine?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/dyno-my-97-civic-ex-coupe-2543199/
dude as i told you before the reason you see it like that is because whenever you dyno a car it tells what wheel horsepower is and not what it says stock to the flywheel? think about it....so yeah keep telling yourself that but whatever
https://honda-tech.com/forums/showthread.php?t=2543199
Redprelude98
Nov 25, 2008 10:42 AM
Layziebtnh055
Apr 15, 2004 06:07 PM
