rear drum squeak
mine do the same thing. when i release the pedal, i hear a squeek from the rear brakes. doesnt squeek when i apply them, so i wouldnt think its because they need replaced. I assumed it was a return spirng on the shoes or something.
ive seen people that drive hard on these 7thgens with rear drums and go 60k with them and still have a TON of meat left of them. most likely they just need an alignment.
The squeal noise could be caused by the shoes contacting the back plates. You can try these two steps.
1. apply some high-temperature brake grease to the contact points between the shoes and the back plates. (make sure no grease on the brake surfaces)
2. replace retaining clips (or just fix them by opening them wider before putting them back on).
jokerstone
Dec 15, 2014 06:41 PM
redcivic44
Feb 18, 2008 01:08 PM
Kapolei INTEGRA
Dec 3, 2005 01:38 PM
redwinqs
Nov 9, 2003 05:08 PM
Charlie Moua
Sep 17, 2002 01:41 PM
