92 civic questions
Old Apr 10, 2009 | 07:51 PM
NeemNutz's Avatar
New User
Default 92 civic questions
Hello HT, This is my first post and hopefully I can get some answers. I'm 18 years old and recently just bought a 1992 EG8 sedan. The car came with a 1999 D16Y8 and my first question is... should I be running a P28 or a P2P ECU? The car came with a P28 but is not chipped. My second question/problem is that when you start the car, the coolant gauge shoots straight up to hot on a cold start and i do not know what to do to fix this. Also when the brakes are applied there is a sudden surge in the idle. The idle fluctuates a lot between 1k-2k rpm. Any input would be appreciated, thanks
Old Apr 12, 2009 | 09:45 AM
NeemNutz's Avatar
New User
Default Re: 92 civic questions
bump
Old Apr 12, 2009 | 09:58 AM
civic_driver's Avatar
The coolant gauge problem could be caused by a damaged coolant gauge or by a damaged coolant temperature sensor.
As for the brake problem that is probably a leaking brake booster vacuum line (the one that's connected to the intake manifold) or the brake booster check valve which is in between the intake manifold and the brake booster.
Old Apr 12, 2009 | 10:50 AM
IhateworkingoncaRs's Avatar
Thats exactly what was going thru my head as I was reading OP's post. LOL
GREAT MINDS THINK ALIKE!
Old Apr 12, 2009 | 04:36 PM
NeemNutz's Avatar
New User
Ok thank you. I'm going to go buy a new coolant temp sensor and see if that works.
wheelerboy12
Jul 23, 2013 10:35 AM
Wkz1gg0a
Honda CR-V & Element
Jan 3, 2012 11:42 PM
IntegraLova
Apr 17, 2008 02:43 PM
