Z6 intake manifold swapped onto D15B2...Code 7
Old Apr 10, 2009 | 06:29 PM
cougar289's Avatar
Default Z6 intake manifold swapped onto D15B2...Code 7
So I just got done swapping a Z6 intake manifold on my already MPFI swapped D15B2. It ran great before the z6 swap, and runs great after the z6 swap too. But the problem is that the ecu is throwing a code 7: throttle angle. So I replaced the TPS sensor on the z6 throttle body....still have a code 7. Tried resetting the ecu....nothing. Finally tried measuring the voltage at the TPS connector and got 5v. I'm out of ideas.
Anyone have any suggestions for this problem?
Old Apr 11, 2009 | 04:59 AM
cougar289's Avatar
Default Re: Z6 intake manifold swapped onto D15B2...Code 7
Wow I've finally found a problem that nobody has a solution for...
Bump.
Old Apr 11, 2009 | 07:48 AM
cougar289's Avatar
I am a shame to the honda community....my retard *** installed the TPS sensor wrong. Fixed it now it runs great!
infamous_nokturnal
Sep 15, 2009 07:17 PM
thesoundofturbo
Oct 31, 2007 06:43 PM
Wazup
Oct 26, 2006 06:25 AM
LilCivic04
Jul 23, 2006 10:47 PM
Vince_badaz
Oct 31, 2003 08:35 AM
