91 DA coolant rises on the resesvoir?
Old Apr 10, 2009 | 05:16 PM
91akira's Avatar
Default 91 DA coolant rises on the resesvoir?
Last week I noticed the coolant was way over the max. Coolant was almost topped off of the reservoir almost spilling. I removed it up to the max. Today, I check to see that its going up over the max again. Why is it doing that?
Coolant is still the light color green. Prestone. I did a drain and flush two years ago.
Thanks for the help
Old Apr 13, 2009 | 08:02 AM
91akira's Avatar
Default Re: 91 DA coolant rises on the resesvoir?
anybody?
Old Apr 13, 2009 | 01:27 PM
lceah's Avatar
Coolant rising can be a sign of your engine over heating...
Is your engine over heating? Do you notice on your temperature gauge?
Old Apr 13, 2009 | 01:32 PM
91akira's Avatar
Needle stays half way from the middle mark.
What are the things that need to be looked at if the engine is over heating. Will it be the Radiator, thermostat, or hoses ????
Thanks
Old Apr 13, 2009 | 01:40 PM
MD426's Avatar
The hoses will start to bulge, temp gauge will raise. Try replacing the thermostat for starts.
Old Apr 13, 2009 | 01:49 PM
lceah's Avatar
So needle is between the middle point and the Hot? or the middle point and Cold?
If the coolant is expanding and rising because engine is over heating, then look at these:
1) thermostat is bad
2) radiator is bad
3) fan motor is bad
4) lower hose
5) water pump
let us know what you find out
Old Apr 14, 2009 | 06:41 AM
91akira's Avatar
2) radiator is bad
3) fan motor is bad
4) lower hose
5) water pump
between middle point and cold. No sign of overheating. So if one of the choices on your lists are bad, should the needle go up to hot?
Old Apr 14, 2009 | 08:35 AM
lceah's Avatar
yes, unless your thermostat is bad...
I would start with changing the thermostat...and since you are doing that, change the hoses too (it's good practice to change them...they are cheap anyway)...
Old Apr 14, 2009 | 08:44 AM
sirmugenpower's Avatar
yeah your thermostat is not opening like it should so it's forcing the coolant to return which is the over flow tank but it could also be you water pump but change the thermostat first that's the easiest thing to do without having to tear everything apart
Old Apr 14, 2009 | 01:32 PM
91akira's Avatar
Thanks for the replies. I'll try the thermostat first.
Old Apr 14, 2009 | 01:33 PM
91akira's Avatar
How much is the thermostat at the dealer?
Old Apr 14, 2009 | 02:54 PM
SLAMMED_DB's Avatar
STOP!!! before doing anything major, buy a brand new radiator cap for like $10. It solved my overflowing reservoir problem and hopefully itll solve yours. but if your car is overheating and overfilling then most likely thermostat. gl wit it!
Old Apr 15, 2009 | 04:37 AM
lceah's Avatar
I got a new OEM thermostat from the Honda dealer for $20 something if I remember correctly...
Old Apr 15, 2009 | 06:40 AM
91akira's Avatar
I haven't done it yet. How is a "bad" rad cap overflowing the reservoir? I'm curious. Thanks for replying.
Old Apr 15, 2009 | 01:54 PM
91akira's Avatar
bump
Old Apr 16, 2009 | 08:02 AM
lceah's Avatar
A bad radiator cap won't be able to help pressurize and let off the excess pressure so that your car doesn't overheat!
You can pressure test the cap to see if it's bad...I think it's 1 minute! Read on the cap for the pressure range. Or you can just buy it and replace it (just make sure you get the correct cap: pressure range).
Let us know what's happening...
Old Apr 16, 2009 | 11:23 AM
91akira's Avatar
Ohh I see.
Update: I was curious of what the bottom of the cap looked like. So I removed the cap, and the gasket rubber looks fine and everything around it. Put it back in. Drove the car for that day. The next day I looked at the resesvoir and the coolant went down to the max line. Prior to that, the coolant was all the way to the top of the reservoir!
Did I fix it somehow by removing the cap? I'll keep monitoring this. Let you know.
Old Apr 16, 2009 | 04:00 PM
lceah's Avatar
I don't know if it just got fixed somehow...
Let us know...
Old Apr 17, 2009 | 07:39 AM
91akira's Avatar
Let us know...
Looked at it this morning before going to work - right on the max. After driving to work- right on the max.
Removing that cap must have done something to fix it. Cause I heard air either coming out or getting sucked in. Ohh well. Its all good for now. Thanks for helping out though.
Old Apr 17, 2009 | 09:08 AM
lceah's Avatar
maybe the cap wasn't tightened correctly...
well, good to hear
WaryDriver
26
Jan 8, 2017 09:54 PM
eman96
Jul 29, 2014 06:53 PM
xTimmyx
Feb 5, 2012 11:07 AM
jvonb
Dec 2, 2005 03:15 PM
FwdCivicHatch
Aug 3, 2004 02:23 PM
