code 41 on a 93 dx hatch, what does that mean?
Old Aug 14, 2002 | 10:27 PM
B_1_8_hatch's Avatar
Default code 41 on a 93 dx hatch, what does that mean?
my check engine light came on so i checked the code. the code came out to be 41. i have this paper that said code 41 is the
preliminary heated o2 sensor or something like that. where is this located, is it the one thats on the headers or what?
93hb
Old Aug 14, 2002 | 10:37 PM
00WhiteEKy's Avatar
Default Re: code 41 on a 93 dx hatch, what does that mean? (93hb)
don't i knwo you? switch trannys yet? haha. go to:
http://tech.hybridgarage.com/tech/index.html
there you will see everycode for your car.
and the O2 heating wire is jsut in the O2 sensor. which is right in the exhaust mani. this stupid thing with wires going into. caution, may be hot if car was running. haha
Old Aug 14, 2002 | 10:39 PM
00WhiteEKy's Avatar
Default Re: code 41 on a 93 dx hatch, what does that mean? (92hatchy)
41 :
Primary Oxygen Sensor - Heater
circuit malfunction
go buy a new O2 sensor dude. cheap as hell.
Old Aug 15, 2002 | 03:14 PM
i haven't put the new tranny in yet. is this sensor the one that goes into the headers? i thought $70 was expensive for this sensor, or am i looking at the wrong one?
93hb
Old Aug 15, 2002 | 05:44 PM
BoM's Avatar
BoM
it might be disconnected by accident.
go under and check.
Old Aug 15, 2002 | 08:55 PM
00WhiteEKy's Avatar
Default Re: code 41 on a 93 dx hatch, what does that mean? (BoM)
well, it depends. if you find a used O2 on here, it will be cheap. but yeah, new O2 are expensive. but used O2 work the same.
Old Aug 15, 2002 | 08:59 PM
well, here's whats going to happen. i'm going to try and find a used o2 sensor, if i don't find one, i'm just going to buy a new one. we are just going to install the tranny ourselves sunday morning, we need to learn how anyway for when ever
we need a new clutch. i'm just going to use the money for the tranny install to buy the sensor. i may head out to a junk yard sat to look for some stock mirrors, should i try to get a sensor from them?
93hb
Old Aug 15, 2002 | 09:08 PM
00WhiteEKy's Avatar
find a car with the sensor, then go in there late some night and get it!
what O2 sensor do you need? I might have 1 laying around here somewhere.
Old Aug 15, 2002 | 09:11 PM
its the primary one so i'm thinking its the one that goes right into the headers.
let me know if you have one.
93hb
Old Aug 15, 2002 | 09:17 PM
00WhiteEKy's Avatar
you have a primary and secondary O2, right? or not. let me know. and what year is your ls? I have a gsr O2 here. becasue my 99 gsr has a primary and secondary O2, but I only used 1. (no cat) and theres only 1 plug for both O2's so I just wired the 1 O2 up. maybe you can see if you can bypass the primary and hook those wires up to the secondary. do you understand what I mean?
Old Aug 15, 2002 | 09:27 PM
i have a 93 hatch dx. i'm not sure if i have one or two o2 sensors. i will look tonight when i get home. the code is 41 - primary oxygen sensor heater.
93hb
Old Aug 15, 2002 | 09:34 PM
00WhiteEKy's Avatar
thats teh same code I had in mine. switched O2 sensors, and it was perfect.
Old Aug 15, 2002 | 09:37 PM
is that the one that right on the headers?
93hb
Old Aug 15, 2002 | 09:40 PM
00WhiteEKy's Avatar
I think so. i dunno. it looked like a spark plug with wires coming out of it. takes a 7/8 wrench to take it off. my O2 sensors were after the exhaust manifold. on the cat. jsut take a look. its the only thing in the exhasut with wires coiming out of. can't miss it.
924drb20
Dec 14, 2010 10:36 AM
chiefrocka
May 18, 2009 04:11 PM
vtec25
Mar 14, 2006 02:39 AM
stattonmw
Feb 1, 2006 11:50 PM
BeavisB16
Apr 29, 2005 03:57 PM
