Any of you R owners have a spec sheet for toda a's?
i need the spec sheet for b series Toda spec A's so that i can get them degree'ed in and i dont have the spec sheet so if anyone has the spec sheet or the info could you please post it? i would appreciate it.. Thanks!
Primary Lobe Secondary Lobe VTEC Lobe
Spec A2 IN 220(6.0mm) 240(9.0mm) 295(12.0mm)
Spec A2 EX 220(5.5mm) 240(8.5mm) 285(12.0mm)
Spec B IN 250(11.0mm) 250(11.0mm) 295(12.0mm)
Spec B EX 250(11.0mm) 250(11.0mm) 285(12.0mm)
Spec C2 IN 250(11.0mm) 250(11.0mm) 300(12.5mm)
Spec C2 EX 250(11.0mm) 250(11.0mm) 300(12.5mm)
thanks but they are not a2's they are just a's and i think there is more info on the spec sheet that i need to get them degree'd in i was told there were certain timing events that you need to know that are listed on the spec sheet that comes with the cams. anyone know anything about that?
JDM-Ownz
Sep 7, 2010 02:28 PM
