help 91 accord
Old Apr 10, 2009 | 09:28 AM
daves91honda's Avatar
New User
Default help 91 accord
ok so around 30to40 mph and 1500 to 2000 rpm the car will start to do little surges or chuggs, like when you up sift to soon(butt it is a automatic) it will stop a soon as i get it above 2000 rpms, give it a little gas, or shift it into D3, which make me think it is a engine problem, but it only does it at that speed range that I can notice, which make me think it is a tranny problem.
the tranny is old 260,000 miles new junk yard engine at 230,000. any ideas thanks dave
Old Apr 10, 2009 | 10:41 AM
jdmwannabee's Avatar
Default Re: help 91 accord
sounds like a distributor problem.
Old Apr 10, 2009 | 10:45 AM
dtapia's Avatar
is their any lights on the dash like the d4 light or the check engine light
Old Apr 10, 2009 | 11:08 AM
New User
no lights or check engine lights on no funny noises just the chugging and only then
Old Apr 10, 2009 | 11:15 AM
dtapia's Avatar
my advise would be to take it to a shop that works on imports and have them diagnose it for you . you will get a lot of feed back on here replace this and that and after you dumped a lot of money find out it worse. these types of problems are kind of hard to diag since this is all on line. and we can only suggest things to try .
Old Apr 10, 2009 | 11:25 AM
New User
that was my plan, but I thought i would see if it was something simple that I could try
Old Apr 10, 2009 | 01:25 PM
cctgene's Avatar
Just a thought - I believe the EGR valve starts to open around 2500 RPMS, so if your valve was not closing completely below that threshold you could be experience some problems. However, once you got above the 2500 RPMS the problem would go away.
Old Apr 10, 2009 | 02:14 PM
New User
no it only does it 1500 to 2500 rpm and only 30 to 40 mph when i am in d. It wont do it if I am 1500 to 2500rpm at 25 mph in d
Old Apr 10, 2009 | 09:37 PM
Andrewne's Avatar
New User
I had a similar problem in my 90 accord. It ended up being my fuel gauge and I was running low on gas. So maybe at least make sure when it happens you know it has gas and maybe check the fuel gauge.
Old Apr 11, 2009 | 09:23 AM
jogo's Avatar
New User
Icon2 Re: help 91 accord
Does anyone know Why the S (sport) light on the dash stays on?Transmission fluid low? 91 SE Accord
Old Apr 11, 2009 | 09:34 AM
jogo's Avatar
New User
I have a 91 Accord SE that the S (sport?) light stays on all the time. What may be the cause for this? Can you help with this problem?
AdamBl
Apr 27, 2011 07:41 PM
jdowen2
Oct 22, 2010 12:30 PM
mitchlemoine
Apr 18, 2008 01:33 PM
geo081661
Oct 16, 2007 07:01 PM
64moon
Sep 20, 2003 07:29 PM
