aem cam gears with FMAX turbo
Old Aug 14, 2002 | 10:17 PM
ELUD THS's Avatar
New User
Default aem cam gears with FMAX turbo
what should be the best setting with the FMAX turbo kit with AEM cam gears. i know it has to be retarded, but which is the best setting done to make the most power for a daily driver? thanks
its for a 5th gen lude.
[Modified by ELUD THS, 11:18 PM 8/14/2002]
Old Aug 15, 2002 | 08:42 AM
ekb18c's Avatar
Default Re: aem cam gears with FMAX turbo (ELUD THS)
go bring it to a dyno and get it tuned. That's the only way you will find out.
Old Aug 16, 2002 | 09:03 PM
ELUD THS's Avatar
New User
Default Re: aem cam gears with FMAX turbo (ekb18c)
thanks for the imput, just curious if any turbo ludes had cam gears with good setting that wored out ok, the dyno here charges close to 40 an hour.
Old Aug 16, 2002 | 09:35 PM
sutrusu's Avatar
every engine is going to be different dude, esp. with a turbo. go get 2 hours worth of dyno time and you'll never have to do it again unless you make a drastic change.
Old Aug 16, 2002 | 09:36 PM
rOby's Avatar
40/hr is cheap as hell. i hear 0 /0 is good
Old Aug 16, 2002 | 10:49 PM
SIK IN DA HED's Avatar
New User
Default Re: aem cam gears with FMAX turbo (roby)
every setup is different... so you have to get yours tuned to your own specifications.
Old Aug 16, 2002 | 11:14 PM
ninesecrx's Avatar
Default Re: aem cam gears with FMAX turbo (dlplayboy)
40 an hour is like robbing the dyno shop. that is beyond cheap. if you go there and dyno it...id say only one hour, maybe you could gain 5-10hp which is a lot of hp for 40 bucks. dont think of it as a loss of 40 bucks...its like buying a go fast good...Mike
Old Aug 17, 2002 | 07:32 PM
ELUD THS's Avatar
New User
Default Re: aem cam gears with FMAX turbo (ninesecrx)
thanks for the tips. i ll double check the amount of $$ for dyno time. i could be wrong.
Double Agent
Jul 27, 2006 10:59 PM
TreLude
Jan 16, 2004 09:52 PM
speeddave
May 23, 2003 09:29 AM
fe519
Dec 3, 2002 04:36 PM
