Will these Integra seats fit my 92 Civic Sedan? (pictures inside)
Old Apr 10, 2009 | 12:28 AM
92-CivicLX's Avatar
Default Will these Integra seats fit my 92 Civic Sedan? (pictures inside)
Will front and rear sears bolt in with no problem? I also paid the junkyard $200 to pull the whole rear brake suspension for a rear dics conversion on my 92 sedan. Anything important I should know or is it pretty much straight forward? thanks
Old Apr 10, 2009 | 01:13 AM
JavierOfReno's Avatar
Default Re: Will these Integra seats fit my 92 Civic Sedan? (pictures inside)
the front seats will work but i dont know about the rear cuz the integra seats lock from the outer side as for the civic coupes lock from the inner part of the seat.
the the discs are pretty straight forward. hope you got the proportioning valve from the integra though. youll want that
Old Apr 10, 2009 | 01:18 AM
nitrousb20_vtec's Avatar
i know for sure the fronts will fit but not so sure bout the back.i got the same fronts in my sedan 94 civic.
Old Apr 10, 2009 | 01:36 AM
sanegb16's Avatar
you gotta do a backing swap on the rear seats
Old Apr 10, 2009 | 10:56 AM
92-CivicLX's Avatar
I just called them and they said something about the bolts broke off on it or something so I cant use the integra for the swap -_- The rear brake suspension from a 95 Delsol should work, right? I wanna be 100% sure so I can call the junkyard back and tell them to pull it from that car. thanks
Old Apr 10, 2009 | 11:29 AM
dj theoretic's Avatar
they should fit, but not too sure. i think they should but you might have to drill a 4th bolt because the seat mounts might be off by an inch more or less. get measurements before you buy them.
Old Apr 10, 2009 | 12:41 PM
Ran4it2's Avatar
where the hell do you live?
i want to go to that junkyard
4 door gsr and **** i wish they had **** like that at my pick and pull
Old Apr 10, 2009 | 01:00 PM
pvt_awol's Avatar
The rear seats WON'T bolt straight in. You'll have gaps.
The Del sol brakes will bolt up just fine. the parking brake cables however will not work. They will be too short. You'll need to get ones from an EX 4 door. $35 a piece from majestic honda.
Old Apr 10, 2009 | 01:07 PM
92'si's Avatar
Seats: Fronts are good, backs... should work, I really dont know I;ve never touched a 4 door civic.
Brakes: Take the whole trailing arm and bolt it right up, and take the prop valve and master cylinder too.
Old Apr 11, 2009 | 12:04 AM
LaOSTaRz's Avatar
should fit and look very sexy.. bump for nice seats
Old Apr 11, 2009 | 06:30 PM
92-CivicLX's Avatar
Thank you to everyone who replied! I'll call the junkyard Monday to tell them to pull the rear brakes, etc. off the Delsol
Old Apr 11, 2009 | 06:37 PM
92-CivicLX's Avatar
lol...I live in Maryland.
EG6 Love
Dec 2, 2009 12:43 PM
Nickb257
Oct 11, 2009 05:38 AM
konidude
Oct 1, 2005 08:09 PM
Silver-Shooter
Oct 23, 2002 11:28 PM
