LS or B20
Old Apr 9, 2009 | 11:23 PM
yee510's Avatar
Default LS or B20
I got a 88 ef hatch. i just wanted 2 know what would be a better swap? LS or B20?
Old Apr 9, 2009 | 11:32 PM
boostedefhatch's Avatar
Default Re: LS or B20
touchy subject, ls is good motor, b20 has thin sleevs very thin heard alot about them cracking imo no matter what build i would go ls/vtec, imo i dont want to take the risk and cant afford sleeving
Old Apr 9, 2009 | 11:36 PM
jdmed3's Avatar
b20s are cheap. imo there good motors for someone lookin to build for drag but ls is all around motor too depends on if you want more torque or easier boost
Old Apr 9, 2009 | 11:45 PM
ls motor are cheap also like i said imo i dont want to risk cracking a sleeve due to high revving there not designed to rev as high as a ls motor could,
Old Apr 10, 2009 | 12:01 AM
yee510's Avatar
thanxs guys, i might go 4 ls/vtec.
What would be better b16 head or gsr head?
Old Apr 10, 2009 | 12:06 AM
b16 for sure, head has way better flow characteristics, its a way better flowing head get the b16
Old Apr 10, 2009 | 12:09 AM
yee510's Avatar
thanxs.. boostedefhatch
Old Apr 10, 2009 | 12:18 AM
no problem, good luck make sure you use the right parts when you build here is a site on the build, http://www.modified.com/tech/0411scc...ine/index.html
Old Apr 10, 2009 | 02:28 AM
88efZ6's Avatar
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
best ls/vtec build I've read to date
Old Apr 10, 2009 | 06:26 AM
Deetz's Avatar
Crazy Honda Guy
Let's some things straight here.....1st off B20's do not have thinner sleeves. Somebody reads something on the internet, then thinks its true- not
The B20 does have their sleeves mounted a different way into the block and are still very strong. The only issue that comes up is under higher boost levels, they are known to have issues with cracking, but this is under big power. Most applications work no problem, and the larger size of the 2.0L makes more power than an LS any day of the week.
Here is a pic of a stock B20 short block, there's nothing wrong with sleeve thickness
Old Apr 10, 2009 | 06:29 AM
~sp33~'s Avatar
EFB055
But it says so, right there on my screen! lol
Old Apr 10, 2009 | 06:35 AM
Deetz's Avatar
Crazy Honda Guy
Once again, miss information!
Both P72 {GSR) and PR3 (B16) heads so so similar we are talking a difference of 2-3hp, and that depends on what rpm you are looking at.
The gsr head makes more power at lower rpm and also has better design quench area which is less prone to detination under boost conditions.
The B16 head makes less power only the low end and only a touch more on the high end, but in truth, the difference between both designs is so close you'd be hard pressed to tell the difference.
Here's an actual dyno of the two heads, stock for stock showing how close power output is
Holy ****, what a difference, NOT
jdm89crxhf
Dec 9, 2011 05:16 PM
skud_dusty
33
Oct 29, 2011 06:20 PM
CB75252
12
Sep 15, 2008 01:28 PM
kmf0211
Jul 7, 2005 09:07 AM
bryanb2
Jan 18, 2005 07:39 PM
