93 civic wont start.
Old Apr 9, 2009 | 08:40 PM
miguel329's Avatar
Default 93 civic wont start.
ok fuel pump isnt priming.. bought a new one thinking bad pump still wont prime.. so i sprayed starting fluid intake started up and shut off did it make sure its fuel prob.. well changed main relay still wont come on... its my moms car trying to get it running its also automatic.. she said last few days it wouldnt start unless she put in nutral..
Old Apr 9, 2009 | 08:47 PM
Former User's Avatar
Default Re: 93 civic wont start.
Does the CEL remain ON or turn OFF after 2 seconds when the key is turned to ON(II).
Does the engine also lack spark at all the plugs?
Check the critical ground wire located on the thermostat housing for looseness and corrosion.
Also check whether fuse 31 (hood), 24 (dash), or 18 (dash) is blown.
Old Apr 10, 2009 | 06:01 AM
miguel329's Avatar
check engine stays on doesnt go off wont even blink , when i use the jumper. cant be spark becuase i put fluid intake start up till it ran out. ground is good... thanks for replying any help is appreciated.
Old Apr 10, 2009 | 06:25 AM
Retrieve the CEL code and check the fuses. It's possible that you have an ECU problem or a bad wire.
Old Apr 11, 2009 | 04:42 AM
miguel329's Avatar
thanks for all the help was the ecu..
Ruggeh
31
Jan 10, 2016 12:00 PM
mtaylor
12
Nov 19, 2010 09:03 PM
Ghost Civic
20
Aug 4, 2010 02:07 PM
blaze_125
56
Jul 13, 2010 07:00 PM
basiceg6
15
Jul 30, 2009 02:30 PM
