1992 Civic - Rusted Rotors & Calipers
Old Apr 9, 2009 | 05:51 PM
americrack's Avatar
New User
Default 1992 Civic - Rusted Rotors & Calipers
I recently bought a 92' Honda Civic EX. It is not great but it's my project car. And when I got it towed the front wheels weren't moving. It just dragged. When I brought it home, I took off the wheels and realized that the rotors, calipers and break pads were all rusted. How can I get the calipers loose to I can take out the rotors?
I will post pictures when I can.
Old Apr 9, 2009 | 05:53 PM
Murk 'EM's Avatar
Default Re: 1992 Civic - Rusted Rotors & Calipers
with a hammer
Old Apr 9, 2009 | 05:56 PM
UserX826's Avatar
Originally Posted by Murk 'EM
with a hammer
haha. tried and true.
Soak it in PBblaster?
americrack's Avatar
New User
I tired that. It still wont budge. Is there a solvent of some sort that could loosen it. I sprayed WD-40 around it. Maybe I'm not using a big enough hammer or not enough power? Got any other ideas if this doesn't work?
heritage36's Avatar
I would probably remove the lower caliper bolt and use a long flat head or short pry bar and pry under the bottom end of the caliper along the bracket the pads sit in, thats what I usually do. Might take a little elbow grease but should eventually come off.
Old Apr 9, 2009 | 05:59 PM
Murk 'EM's Avatar
use a bunch of pb blaster and a big hammer or a tourch
Old Apr 9, 2009 | 06:00 PM
americrack's Avatar
New User
Thanks. I'll try the PB Blaster, Hammer and the prying with a flathead. I'll update as soon as I can.
Old Apr 9, 2009 | 06:08 PM
tazeat's Avatar
Take the hole assembly off and replace it. Good working brakes are essential.
To get the caliper/pads off the rotor, **** do what you gotta do, hammer, torch, sawzall whatever. I'd say the bigger hammer the better lol. Rust, corrosion and seized bolts are a bitch .
Old Apr 9, 2009 | 06:10 PM
americrack's Avatar
New User
Hahaha I will try EVERYTHING. And yes they are a bitch. Me and idiot self almost stripped the rotor screw trying to get it off.
Old Apr 9, 2009 | 08:09 PM
americrack's Avatar
New User
Rusted!
Old Apr 9, 2009 | 08:18 PM
RagnarX's Avatar
Holy crap how long was that car sitting for? Looks pretty seized to me.
Old Apr 9, 2009 | 09:48 PM
Hanmin's Avatar
spray brake cleaner, and pour some brake fluid on it if you have any extra. or do this
http://www.fordmuscle.com/forums/oth...ctrolysis.html
Old Apr 10, 2009 | 08:09 AM
americrack's Avatar
New User
Yea. It is seized and the car was sitting long.
Old Apr 10, 2009 | 08:14 AM
sde780's Avatar
Heat it up and slam it with a hammer
Old Apr 10, 2009 | 08:38 AM
dmotoguy's Avatar
holy ****, was it sitting at the bottom of a lake?
I'd go to autozone and get new everything...
Old Apr 10, 2009 | 08:23 PM
UserX826's Avatar
It looks like a horror movie where the bad guy takes his mask off. There's his skin
Old Apr 10, 2009 | 09:55 PM
americrack's Avatar
New User
RE: PB BLASTER
How does it really work? Does it remove the rust? If so, how long should I leave it soaking?
PS. Sorry about the noob questions.
Old Apr 10, 2009 | 10:06 PM
thumper64's Avatar
I had this problem on a car. Compress the caliper like you're going to take it off to do brakes. Use a hammer and punch, chistle, etc to knock the pad off the rotor. Spray PB Blaster on the bolts and let it sit before doing a brake job.
Old Apr 10, 2009 | 10:10 PM
thumper64's Avatar
PB Blaster has some sort of "penetrating catalyst", or that's what the bottle says. I don't know how it works, but whatever makes it smell bad must help.
Let it sit for an hour, or heck, overnight is better.
Old Apr 10, 2009 | 10:15 PM
mistajdm's Avatar
keep us posted!
Old Apr 10, 2009 | 10:16 PM
americrack's Avatar
New User
Thanks. I'll get some, try it and I'll keep you guys posted. Stay tuned!
Cherokee1979
Honda Civic (2001 - 2005)
Jun 23, 2014 01:04 PM
need2shave
Honda Civic (2006 - 2015)
Aug 28, 2013 08:04 PM
jdmekrobot
14
Mar 19, 2008 02:28 PM
Knight1
Dec 10, 2005 09:35 AM
Flux
Apr 13, 2003 11:05 AM
