93 civic gsr swap erratic start
Old Apr 9, 2009 | 05:10 PM
Inliner's Avatar
Default 93 civic gsr swap erratic start
OK swapped the GSR in on sunday, and 3 or 4 times now it just will not start key has power dash lights up fuel pump is on I can hear a relay click behind the mirror switch but not crank but if I have someone sit in the car and hold the clutch in while i jump from the hot wire of the starter to the little wire which is supposed to start it it fires right up. and other times i get in and it starts no problem what so ever.
sorry for the run on sentence there but im frustrated, the problem happened twice today I just left it run after that.
please fire any questions you may have at me.
Old Apr 9, 2009 | 06:34 PM
Former User's Avatar
Default Re: 93 civic gsr swap erratic start
Check the starter switch located at the top of the clutch pedal. It's probably bad or the pedal needs to be adjusted.
Black R
Apr 8, 2023 07:14 AM
hondata760
Nov 12, 2015 02:08 PM
lgwells1
17
Jul 24, 2014 03:01 PM
tauniFLA
Jun 21, 2012 05:44 AM
liljpw16
Apr 26, 2006 07:37 PM
