Throttlebody whistling?
Old Apr 9, 2009 | 03:21 PM
JaydmEg's Avatar
Default Throttlebody whistling?
Just slapped on my type r manifold on my Gsr and it makes a whistling noise from the tb like between 3-4 and car idles like. @ 1300 and 1500 checked everything and everything seems ok help?
Old Apr 9, 2009 | 03:23 PM
Davus's Avatar
Default Re: Throttlebody whistling?
Everything is okay. Our cars whistle a bit at certain RPM/throttle positions.
As for the high idle, replaced intake manifold gasket as well as throttle body gasket (with correct application) and torqued to spec in proper sequence?
Old Apr 9, 2009 | 03:26 PM
1DayIllBFast's Avatar
I just replaced my SGR mani for the S2 Mani and it idled high at first also. since it is a diff. mani with bigger plenums and runners you might want to adjust your idle screw, thats what i had to do. so try that out and let me know.
Old Apr 9, 2009 | 03:35 PM
JaydmEg's Avatar
Tryed the throttle screw it's as low as it goes. Didn't replace throtle body gasket.. And didn't torque anything lol we made sure all the bolts were tight tho
Old Apr 9, 2009 | 03:40 PM
Well like i said i just replaced mine this past weekend and i didnt torque anything either which i know is dumb ha but hey when you dont have a torque wrench what you going to do. could just be your IACV is dirty. all you have to do is take the 2 bolts out of it and take a look at the screen on one of the holes. If it has dirt and gunk in it then taht could be your problem. Also check double check and triple check for vaccum leak somewhere.
Old Apr 9, 2009 | 04:53 PM
JaydmEg's Avatar
That's wat I think it is a wack vaccum leak that I can't find that high idle pisses me off =[
Old Apr 9, 2009 | 04:54 PM
R666_EK's Avatar
Does the idle stay high or does it eventually come down when its warm?
Old Apr 9, 2009 | 04:58 PM
If the idle comes down when its warm than thats normal. If it stays your need to check vac. leaks,or clean IACV, or clean FITV, or check TPS position.
Old Apr 9, 2009 | 05:00 PM
JaydmEg's Avatar
I'm gonna trying cleaning that **** out cuz it stays...
Old Apr 9, 2009 | 05:04 PM
R666_EK's Avatar
This might be a dumb question, but did you leave enough slack on the throttle cable? It isn't pullin on it at all is it? Usually a bad IACV would cause a jumpy idle. The FITV (if equipped) would be something worth looking into also.
Old Apr 9, 2009 | 05:16 PM
I agree with EK man i would check your FITV first. Take it apart and look at the white ring on the inside. Sometimes after while it starts to screw out leaving a gap in between so air doesnt stop coming threw when warm. So if it isnt screwed in all the way make sure you do that.
Old Apr 11, 2009 | 02:26 PM
JaydmEg's Avatar
How do I stop the whistle it's really annoying I'm sure there's a way to stop it...
Old Apr 11, 2009 | 02:39 PM
MonkeyMagic's Avatar
put the stock airbox/filter/muffler assy back on.
emooheo
Feb 24, 2008 04:54 PM
Hardedge
Dec 9, 2007 09:18 AM
90AcuraIntegra04
Feb 4, 2006 02:18 PM
mingbling
Mar 15, 2004 11:37 AM
Skittle
Jul 3, 2003 09:41 AM
