Time sert vs Heli Coil
Old Apr 9, 2009 | 01:43 PM
JDMproblem's Avatar
Default Time sert vs Heli Coil
Blew a head gasket on my a6..some threads in the block were on the head bolts when I took them out..which one should I use to fix this??
Old Apr 9, 2009 | 02:03 PM
vtecmonster001's Avatar
Default Re: Time sert vs Heli Coil
are you sure it wasnt something like thread lock that were on the bolts? i get that all the time, but take a second look to see; its really thread lock instead of aluminum shavings .... but worse case, you might have to re-thread the block and get a diff. sized bolts to compensate. and i like to use heli coil.
Old Apr 9, 2009 | 03:53 PM
non-VTEC's Avatar
time serts work the best. but the time sert kit is extremly expensive (over 300 bucks i belive).
heli-coils will work if properly installed. just be paintent when installing them and make sure the bolts thread in smoothly after the insert is installed.
Old Apr 10, 2009 | 02:11 PM
dpaton's Avatar
Time-sert. Check out the pictures and videos on both sites, and it'll be obvious why. There's also a reason that Time-Sert is used for factory repairs. Spend the money, fix it right.
Old Apr 10, 2009 | 02:15 PM
mar778c's Avatar
Community Builder
Community Influencer
Time sert.
Old Apr 10, 2009 | 03:32 PM
Honda Sport's Avatar
instead of trying to fix it, why not just get another a6 shortblock or any d-series shortblock. probably the same price if a little bit more then time-sert or helicoil.
Old Apr 10, 2009 | 05:00 PM
PyroProblem's Avatar
Time sert hands down...
Do it right or do it again..
Old Apr 10, 2009 | 06:58 PM
team1320_k26eg's Avatar
Time sert
Old Apr 10, 2009 | 07:26 PM
mikesrex's Avatar
If you know someone with a time sert kit, pay them to install the time serts.
if not, then just buy another block. it's the cheapest way out. DO NOT use helicoil to "fix" your problem.
Old Apr 10, 2009 | 08:34 PM
Top Ramen's Avatar
The Time Sert design is fundamentally better than HeliCoil.
Old Apr 11, 2009 | 03:31 PM
JDMproblem's Avatar
I would but I jst got it machined + spent about $300 to assemble it, so I would rather not lol..so time sert it is..but is there a kit for an a6?
Old Apr 12, 2009 | 05:11 PM
dpaton's Avatar
http://www.timesert.com/html/honda.html
Old Apr 12, 2009 | 05:13 PM
pasaunde's Avatar
The Stealerships I know carry the time-sert kits for repairs in-house/customer. If you still have the block out of the car I would carry it up to dealership for a proper repair.
Having said that, I know a guy who repaired an B20 block using the $90 North Star Kit + $30 for the 30mm long head stud (Time-Serts).
Good Luck
Old Apr 13, 2009 | 12:44 PM
JDMproblem's Avatar
will do.
Old Apr 13, 2009 | 02:46 PM
h22crxpwr's Avatar
many machine shops can do this for you so you don't have to buy the kit and risk messing up your block even more..
Time Sert that is.. the local shop near me charges $20 a hole or $25... havent taken one in a while..
Tool420
19
Sep 12, 2014 12:31 PM
leadfoot78
Apr 25, 2004 11:32 AM
rocket_R
Feb 29, 2004 04:15 PM
civicmatt
May 5, 2003 08:42 PM
