A6 swap, new harnes has a squre plug
i am swapping a new long block a6 into my wagovan, i am not sure what year the new motor is but the engine harness that came on it has a square plug on the driverside shock tower instead of a round one. i don't have my old harness, is there a pinout diagram somehwhere to wire this?
your D16A6 engine harness with square 6-wire connector at the driver's side is the 1988 model - the only difference between the 88 and 89-91 connectors is the 88 didn't have a Fast Idle Control Valve so it has 2 less wires - you could repin a round 8-wire connector onto the harness and just match up the wire colors on both sides of the connector
REDEM1FTW
13
May 11, 2010 10:08 AM
