Just another day...
So sure alot of us have had this problem... Your power locks stop working. Usually you can push them manually and everything is good to go. Well in other cases they lock up and don't allow you to lock them. It's a 95 Integra LS.
Starters, gotta pull the handle.
Then removing the Window track to remove the guts.
Now got it out... Removed the motor and cracked into it to check the teeth on the gear. All mechanical parts are soaking in WD40.
It all started with my key not turning so I disected the handle and removed the lock and checked the pattern to make sure my key was correct. Loosened it up with WD40 also and truns now. But then I put it all back together and manually and with the switch I tried to lock it and still no go. After soaking the rods and junk I'm going to put it back in and give it a shot. Anyone have any other suggestions??
ndrew2505@yahoo.com
Dec 13, 2010 09:47 PM
