power locks and drivers window stops working most times
ive got a 91 accord ex and one day the power locks stopped working. went for a few weeks not working then started again then a few weeks later my drivers side window stopped working. was running errands today and both started working again for a little while but now theyre back to not working. ive searched a few forums and google and some newer models have an intermittent wiper switch solution but my make/model doesnt have one that i know of. all the other windows seem to work fine but both the drivers side window and door lock work for a while then quit then start again. does anyone know of what may be causing the problem and a way to fix it?
also can a mod or admin remove the @yahoo from my username. made a mistake during registration..
Re: power locks and drivers window stops working most times
how many damn windows threads do I have to see each time I get on this damn forum. Learn to search noob.
https://honda-tech.com/search.php?searchid=332974 =nothing
ive also read the FAQ sticky and havent seen anything about a model similar to mine.
Sounds like it is a problem with a switch.
When the power locks/window does not work, do the switches on the other doors work?
It may be the plug that goes into the drivers door sometime conecting/disconnecting. If the 4th gen is like the 5th gen, the drivers door has the master lock switch. So if it is disconnected, non of the other lock switches will work.....if I remember correctly.
