Trailing arms on LS vs GSR.
Old Apr 9, 2009 | 08:23 AM
import-tooner's Avatar
Default Trailing arms on LS vs GSR.
Is the trailing arms and control arms different on an LS than a GSR? The reason I'm asking is I have a complete wrecked 97 gsr but the trailing arms are bent. I was going to swap everything, disc's etc. to my 98 civic dx until I found out they were bent. I just found a LS integra at a local junk yard that still has it all and I wondered if it would be any different. I was going to get it all, calipers, disc, trailing arms, lca's (you get the point)
If the only difference was the disc setup then I'd take the trailing arms and put the gsr disc assembly on it then swap that to my 98 dx.
Sorry if this is confusing.
Old Apr 9, 2009 | 08:26 AM
HondaTom87's Avatar
Default Re: Trailing arms on LS vs GSR.
If they are both 94-2001 models then the trailing ars should be a direct bolt on affair
Old Apr 11, 2009 | 03:59 PM
Thanks. What about the rear dics?? are they any different?
Old Apr 11, 2009 | 05:21 PM
Dogginator's Avatar
Daisy... Daisy...
GSR and LS brakes are the same.
B18C Turbo
Jul 20, 2008 06:14 PM
the_illest_soldier
Apr 4, 2005 04:27 AM
kaj
Suspension & Brakes
20
Feb 6, 2005 05:03 PM
underb00steg6
Jul 9, 2004 12:34 PM
