z1 compression ??
Old Apr 9, 2009 | 08:05 AM
JDMblkguy's Avatar
Default z1 compression ??
i have a d15z1...i know e-con. anyways the rings were bad and i had a spare b7 block. thought of stupid ideas and i put the b7 pistons and rods in the z1 with an ex trans. im hoping to build this block and kick the economy out just a stupid build at the. i was wanting to know what my compression would be now?
Old Apr 9, 2009 | 08:10 AM
Hanmin's Avatar
Default Re: z1 compression ??
google something like honda compression calculator. With the z1's combustion chamber, you will end up with a high compression vtece minime setup. I'm collecting parts for a minime setup using the vtece head with some other parts, lmk how yours turn out.
Old Apr 9, 2009 | 08:24 AM
JDMblkguy's Avatar
a guy on ch.com said it would be about 13:1 and i was just seeing if anyone knew better than some ppl
Old Apr 9, 2009 | 08:29 AM
Hanmin's Avatar
http://www.c-speedracing.com/howto/c...c/compcalc.php
http://www.zealautowerks.com/dseries.html
use both of those to make your own combination and get the information you need, the d15b7 stroke is 84mm or 84.5mm i forget.
Old Apr 9, 2009 | 09:56 AM
JDMblkguy's Avatar
any one else
Old Apr 9, 2009 | 10:17 AM
TravisCadello's Avatar
i got 10:22 with a d15B block and Z6 head and 3 layer head gasket.
Old Apr 11, 2009 | 06:51 PM
JDMblkguy's Avatar
yeah i got the same head gasket to
mike93eh2
Feb 11, 2009 08:09 PM
mugenwannabe
Aug 19, 2006 07:42 PM
Jun 26, 2004 08:51 PM
Mentat Ghola
14
May 11, 2004 02:35 PM
