Type R turbo? how many pounds?
Old Apr 9, 2009 | 07:50 AM
EL TYPE R's Avatar
Icon6 Type R turbo? how many pounds?
Whats the safe boost level for a stock internal Type R. with 2 1/2 piping, 310 injectors, walbro fuel pump, GARETT GT28 Ball Bearing turbo with internal wastegate Set to 7 pounds, and a HONDATA S300. It Will be Tuned by CHURCH.
I WILL NOT BUY PISTONS AND RODS FOR NOW
Old Apr 9, 2009 | 08:47 AM
TIGboy's Avatar
Default Re: Type R turbo? how many pounds?
tune it at 7.
Old Apr 9, 2009 | 08:58 AM
boostedcivicsir's Avatar
Mr. Badwrench
you arent goin to make it too far on the 310s
Old Apr 9, 2009 | 09:02 AM
Ls_dx's Avatar
Yeah 7 would be safe and still rip pretty good
Old Apr 9, 2009 | 09:52 AM
TheShodan's Avatar
Moderator
7psi is the maximum with those small 310cc injectors. No one is saying that you need 1000cc or anything, but I'm sorry, those 310cc will not do much.
Old Apr 9, 2009 | 12:30 PM
Ls_dx's Avatar
Maybe get some bigger injectors for peace of mind.
Old Apr 9, 2009 | 02:37 PM
Unknown Racing's Avatar
yeah injectors are too small
Old Apr 9, 2009 | 02:40 PM
Turbo-LS's Avatar
i dont think the 310s will even handle 7 psi but i could be wrong
Old Apr 9, 2009 | 07:03 PM
Turbo-LS's Avatar
450's are good for 300whp range so im sure the 310's arent good for much more than an all motor setup or a few psi
Old Apr 10, 2009 | 07:50 AM
EL TYPE R's Avatar
My brother ran 310 injectors at 7 pounds on a gsr, made 260hp. I wanted to make sure my type r engine can hold 7 psi with a good tune, constant. what do you think?
Old Apr 10, 2009 | 07:58 AM
TheShodan's Avatar
Moderator
I think that you need to be safer than risky on a Type R engine. That is VERY different than a GS-R in terms of static compression. Please stop trying to use PSI pressure as a measure. Your turbocharger may be different than his, so "7psi" is irrelevant...
That's what "we think".
Old Apr 10, 2009 | 08:28 AM
ACTION JACTION's Avatar
IMHO I would not even boost on injectors that small. Least, least I would go is 440cc. get some DSM injectors for cheap, they are 450cc.
Old Apr 10, 2009 | 08:38 AM
EL TYPE R's Avatar
So my best choice is not to mess with the Type R engine right?
Damb, ok. Whats a good piston/rod set up?
Im boosting the R, I bought a Garett Gt28, Hondata S300, Spearco intercooler, Injectors, walbro fuel pump...
ok, what pistons/rods combo? compression?
Old Apr 10, 2009 | 09:27 AM
anjgsr's Avatar
get 440's then tune it on 10lbs, i got 302whp on that setup with stock internals and 98,000 miles on it
Old Apr 10, 2009 | 10:24 AM
Turbo-LS's Avatar
i wouldnt even do 440's i personally would run some 550's or 650's to be 110% sure you have enough injector. type r engine can handle boost but it needs a seasoned tuner and the proper fueling
Old Apr 11, 2009 | 07:41 AM
93CX's Avatar
What??? No one even mentioned pistons and rods, and no one told you not to turbo your car. Just return the injectors to the store you bought them from for a bigger size.
Old Apr 11, 2009 | 08:09 AM
still_slow's Avatar
I ran a 3mm head gasket ARP head studs with a T3/T4 57 trim turbo at 14psi making 346whp been running strong for 2 years now with many track days.However I was running 750cc injectors.
B18 rider
Aug 8, 2008 10:51 AM
b18_ef_hatch
11
Mar 5, 2006 10:21 AM
civic_driver
Aug 27, 2005 06:51 PM
Turboredteg
Jan 26, 2005 02:19 AM
1stealthls
Mar 29, 2002 06:19 AM
