trouble shooting h2o
Old Apr 9, 2009 | 06:51 AM
Full_JDM_Eg6's Avatar
Icon3 trouble shooting h2o
yo just got a 96 teg. ls, need quick help. problem is low coolant in radiator and resivor is full. doesnt run hot or leak, have to put more coolant in every 3 days or so. any info. would be very help full. thanks in advanced....
Old Apr 9, 2009 | 08:31 AM
HondaTom87's Avatar
Default Re: trouble shooting h2o
possibly a bad head gasket... that would be my first thought... pull the plugs if they look extremely clean then you are probably burning coolant
Old Apr 9, 2009 | 06:28 PM
bump
Old Apr 10, 2009 | 07:28 AM
ok thanks look into it today.
Old Apr 10, 2009 | 05:07 PM
bunp... nope not that anyone else?
Old Apr 10, 2009 | 05:20 PM
teggything's Avatar
when you thermostat is at normal driving condition pop the hood and feel oth hoses if they arent the same temp,and about as full in both hoses then your water pump might be going out
Old Apr 11, 2009 | 07:40 PM
ok have to try that tomorrow...
Old Apr 12, 2009 | 07:01 AM
Tegraracer90's Avatar
also check the oil...if its really high off the top mark....your "missing" coolant is laying in the bottom of your oil pain....in turn meaning...bad head gasket
Old Apr 12, 2009 | 08:03 AM
ok but it water is laying in the bottom of the pan wouldnt i see it on the dip stick?
Old Apr 13, 2009 | 05:56 AM
aw shift... i dont know... guess ill just change the hoses, therm., and head gasket, and go from there. thanks everyone
A Tribe Called Honda
Feb 21, 2008 03:19 PM
jdmsohc2nr
Dec 6, 2007 06:04 PM
Jeff1119
Nov 14, 2007 10:07 AM
ALMXDUPINTEGRA
May 11, 2005 11:05 AM
spcrxracer
Feb 27, 2005 11:16 AM
