how do i remove door pannel on manuel windows
There is One screw behind the inside door handle.
Another in the Cup handle. And 3. maybe four i forget behind the speaker cover, The speaker cover just pops off. Your going to want to take the speaker out too and unplug it.
To get he window crank off there is a C clip behind it, Its gold. They make a tool. I just use a skinny screw driver to pop it off. You cant miss it.
Then to get the door panel off completely there is snap clips at the bottam that just pull out, Do them first then pull the bottam out a few inches and pull up, The top of the door panel slides over a lip on the door. It should pop right off then.
Window pop off the tracks??
serious
Sep 6, 2002 04:40 PM
