96 ex transmission mystery
Old Apr 8, 2009 | 09:06 PM
oblivion2kx's Avatar
Icon6 96 ex transmission mystery
Ok so I have a 96 accord Ex vtec with auto tranny.
Back in november my trans flared after shifting gears and then one day on the highway a CEL came on and it went to redline and hardly shifted from second after that. I ended up disconnecting the battery for a half hour then connecting it. CEL is off but it shifts into second gear at 5k rpm. I decided to do a trans fluid change, but before I did that I jacked up the front end to check for leaks.. no leaks. Then I put it back down and it drove fine, shifted normally. I let it sit for a day, started shifting erratically. I changed the trans fluid with atf-z1 3 quarts and cleaned the magnetic plug. Shifted beautifully and I decided to take it on a test drive.....
After about 20 min, it started to act up slowly.. then at 73mph and 3450 rpm CEL kicks on and it gets worse. I pulled two codes, P0740 and P0715 regarding the torque converter and speed sensor..
Can both of these go bad at the same time? Would it even be worth replacing individually vs new tranny?
Old Apr 9, 2009 | 12:28 PM
Default Re: 96 ex transmission mystery
bump
need help people..
Old Apr 9, 2009 | 05:23 PM
bbbuuummmppp
Old Apr 9, 2009 | 06:21 PM
The-Kid's Avatar
Hey, I got that code, P0715 on my 96 EX coupe. First of all, I would check to make sure all the sensors have correct resistance and all the solenoid works.
My transmission gave out on me on the way home from the dealership. I had to replace it. Who knows, it might be just a bad sensor. Sorry for the bad news.
My TQ started making some whirring/whinning sound when cold. I thought it was my intake, but it wasn't. I guess what happen is that the torque convertor just gave out, making the clutches hot, and slowly burning out the tranny.
Replacement cost for mine was $1000 with labor with a used tranny from the junkyard. Works well.
I did alot of research to this, and one thing you may also want to try is tranny flush. I heard some success story with this, but with a fragile Honda tranny, I don't know.
theschweizer
Apr 21, 2015 05:42 PM
69GTOby
Jun 4, 2013 06:50 PM
Charri
Sep 16, 2011 03:57 PM
oblivion2kx
Transmission & Drivetrain
Apr 10, 2009 03:12 PM
Nizzy
Apr 25, 2003 01:49 PM
