Vibrating when brake applied.
Old Apr 8, 2009 | 04:56 PM
hermtm2's Avatar
Default Vibrating when brake applied.
Hello.
I noticed a lot of vibration when the brake is applied on the highway.
The pads and shoes were replaced about 5 months ago. What could make this problem? (Anyway, mine is a 2000 Ex 2dr. auto. 137k on it.)
Thanks.
Old Apr 8, 2009 | 05:12 PM
tfeagley's Avatar
Default Re: Vibrating when brake applied.
Have you checked the rotors to see if they are warped?
Old Apr 8, 2009 | 05:14 PM
97twodoor's Avatar
Rotors are no longer parallel.
Old Apr 8, 2009 | 05:33 PM
hermtm2's Avatar
Is it only matter of the rotors or with the rear drums?
This is my first car which don't have rear disk brakes.
Thanks.
Old Apr 8, 2009 | 05:41 PM
biggjerryc's Avatar
if you can feel it in the steering wheels its 99% sure the rotors. usually drums dont take enough beating to warp. if its not the rotors.. possibly bad alignment has caused uneven tire wear. or even a bend in the rim
Old Apr 8, 2009 | 05:47 PM
wheelmanbg's Avatar
Have your rotors resurfaced and that should fix your problem.
It's only like 30 bucks for 2 if you take them off yourself.
Old Apr 8, 2009 | 05:52 PM
andoxviii's Avatar
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
405hp
Honda Civic (2006 - 2015)
14
Nov 2, 2009 05:14 AM
themikewoo
15
Oct 10, 2007 06:09 AM
teggsr925
Mar 3, 2007 01:35 PM
Krnbk2
May 28, 2004 12:47 PM
Propulsion
Apr 8, 2002 07:21 AM
