Anyone using the F22 STR Cast Manifold or simular? What downpipe are you using?
Old Apr 8, 2009 | 02:51 PM
KidFrost's Avatar
Default Anyone using the F22 STR Cast Manifold or simular? What downpipe are you using?
OK... Heres the manifold I have. I am using a t3/t4 hybrid turbo.
Heres the downpipe I have. Its going to take quite a bit of modification to work but I dont think I have much of and option.
Any insight. Is there any other downpipes available for an accord? For this type of manifold?
Since it puts the turbo straight out its kinds hard.
TIA
-kidfrost
Old Apr 8, 2009 | 03:14 PM
NeKe1point0's Avatar
Default Re: Anyone using the F22 STR Cast Manifold or simular? What downpipe are you using?
You're going to have to cut up that whole downpipe just to make make it work.
You may not be able to use that mandrel bend coming off the 5 bolt either. may need to be pie'd. (if you are keeping your a/c & p/s).
It looks like a nicely fabbed downpipe though just suxs it has to go back under the torch...
Old Apr 8, 2009 | 03:29 PM
KidFrost's Avatar
i know i am going to have 2 cut this one up. but i had no other choice, i dont think unless someone makes one for this manifold.
thats what im tring to find out.
well i am ditching A/C and i think it will clear the P/S
Old Apr 8, 2009 | 03:37 PM
You should be able to make it work it just sux you gotta cut it all up. You may need a little more material so you can clear the pan. Thats the only prob i can foresee.
good little project if you can tig.
Old Apr 8, 2009 | 04:15 PM
KidFrost's Avatar
yes thats what i figured.
i will also have 2 reclock the 5 bolt flange and extend the down shoot.
i cant tig but i have a hook up....
Old Apr 27, 2009 | 10:35 AM
KidFrost's Avatar
so no one makes a down pipe for this manifold??
WTF its like the only ****ing manifold you can buy...
garados
Welding / Fabrication
Nov 29, 2009 02:33 PM
mattf22b1
May 22, 2006 04:35 PM
adotlee
Mar 9, 2004 04:42 PM
Armaan
Dec 25, 2003 05:08 AM
