need help on wiring...
Old Apr 8, 2009 | 02:13 PM
3lo's Avatar
3lo
Default need help on wiring...
i want to make my brake light show turn signals. most of thje new cars come like this now.
each taillight has two bulbs for brake lights, i just want to use the outer ones for turn,
basicaly when i engage left turn signal and brake at the same time my right tails are both red, but left inner is red outer is flashing. i know its possible so i dont need any post that its impossible, i just need the diagram how to connect the trailer light converter in to the civic circuit, also do i need 1 or 2 flashers?
thanks
Old Apr 8, 2009 | 07:32 PM
3lo's Avatar
3lo
Default Re: need help on wiring...
anyone?
Old Apr 9, 2009 | 06:35 AM
egVJMsol's Avatar
bump
Old Apr 9, 2009 | 06:53 AM
waaBAAH's Avatar
maybe i am misunderstanding
you want your outer tail to flash with blinker, and your inner tail to be brake light?
i thought that was how stock is?
im not at work but i can pull up a diagram for you if you can explain it a little better to me. sorry i cant grasp the concept right now
Old Apr 9, 2009 | 11:39 AM
R666_EK's Avatar
Just tap the wires. Run the signal from the regular turn signals to the outer brake light. Should work right?
Old Apr 9, 2009 | 04:48 PM
3lo's Avatar
3lo
no, see i want the brake light to work when signal is off, but when signal is on the brake light dotn work and the light is flashing (turn signal)
Old Apr 9, 2009 | 04:50 PM
R666_EK's Avatar
Well the brake light should work if the signal is off. When the signal is on the brake light shouldn't stay solid.
Old Apr 9, 2009 | 05:35 PM
cash459's Avatar
R666 has it right....
all you need to do, is splice the turn signal wire into the brake light that you want to flash & it should only flash when the signal is activated & act as a regular brake light any other time...
Old Apr 11, 2009 | 04:38 PM
3lo's Avatar
3lo
just tried it out and it didnt work, when i spliced it, the brake work but when i turn the signal all the brake lights start flashing.
Geis
Jul 12, 2015 04:26 PM
justinkase96gsr
Lighting
Feb 27, 2013 08:48 PM
3lo
Lighting
Apr 9, 2009 05:01 AM
cycoclown
Apr 16, 2007 10:30 PM
Gonzo_SiR
Audio / Security / Video
Jul 19, 2003 02:03 PM
