98 Accord with 55 mph shimmy
Old Apr 8, 2009 | 12:39 PM
speeddog's Avatar
New User
Icon4 98 Accord with 55 mph shimmy
My 1998 accord has a front end shimmy at 55 mph to 60 mph. Below 55 & above 60 the shimmy goes away? The front tires are in nice shape with no broken belts, tires have been spin balanced, Tires show no uneven wear due to alignment ??
Could this be a C.V. joint or axle shaft problem ? or internal tranny problem ? Sway bar ?
Any Ideas ?
Thanks, Speeddog
Old Apr 8, 2009 | 01:06 PM
Elvis1977's Avatar
Default Re: 98 Accord with 55 mph shimmy
Any Ideas ?
Thanks, Speeddog
Rebalance tires again. I have a 98 accord and noticed that Michelin tires work the best on this car.
Old Apr 8, 2009 | 01:42 PM
FunnyVictor86's Avatar
i found it that when its more the opposite of his situation ... if the tires were out of balance they would shake at higher speeds ... not at lower speeds ... how are your motor mounts?
Old Apr 8, 2009 | 01:51 PM
96F22B1Accord's Avatar
also check the rims, on many balance machines will tell you it's zero'd out, but the rim can still be bent.
Old Apr 8, 2009 | 01:56 PM
GoLowDrew's Avatar
Old Member
25 Year Member
X2. OEM or aftermarket wheels?
KhornLuda
Nov 29, 2012 07:23 AM
vectorxy
Sep 27, 2010 04:02 PM
Fraggle
Mar 14, 2009 05:04 AM
kuthey
Dec 13, 2005 10:32 AM
Mindmotion
Mar 13, 2004 01:41 PM
