06 rsx issues
Old Apr 8, 2009 | 10:54 AM
pias's Avatar
New User
Default 06 rsx issues
Heres my story. Kid comes into my shop with an 06 rsx pulled apart with a blown motor and he wants it replaced. Not sure what happened but we take the job anyway. Well we couldnt find an 06 rsxs motor so the yard told us the 03 motor will work so we go ahead and get that and swap it in, moving over all the sensors and manifolds from the old motor. Well when it comes time to get it going the car runs like ****. It barely idles and bogs when free revving the motor. When you actually drive it it doesnt seem to bad but when its not under load its a complete pig. It idles all over the place and after a few starts of the motor it wont run for more than a few secs before completely killing itself. According to the modius its enabling fuel cut killing the motor no matter what i try to do to keep it running. Map sensor doesnt seem to move as much so we replaced it and its staying around the same. around 3.5 volts and 120 kpa. We adjusted the valves but it didnt help. the yard says we need to reprogram the ecu but the dealer says we do not. ANy ides?
Brian
Old Apr 8, 2009 | 11:02 AM
josh's ep3's Avatar
Function > Form
Default Re: 06 rsx issues
The 05-06 ECU's are different than the 03-04 RSX ECU's. So I believe if you get a stock 03-04 ECU you should be fine.
Old Apr 8, 2009 | 11:06 AM
josh's ep3's Avatar
Function > Form
In fact, I am almost certain that is your problem. You will need the new ECU and to get the immobilizer reprogrammed at the dealership.
Old Apr 8, 2009 | 11:08 AM
pias's Avatar
New User
Hmm... can anyone confirm this? Just wanna make sure i dont waste the time and money and have negative results Thanks guys!
Old Apr 8, 2009 | 11:21 AM
Aznsensation's Avatar
im no ... "honda tech" ... but that makes perfect sense to me.
Plus his name is josh, that's credible as hell!
Old Apr 8, 2009 | 11:35 AM
josh's ep3's Avatar
Function > Form
Word^
Old Apr 8, 2009 | 11:40 AM
nahonda04's Avatar
Surje.motorsports
Reprogram ecu at dealership. The people at ur dealership are retarded. I had to prove to mine that it was even possible!
Old Apr 8, 2009 | 11:43 AM
Remind me never to go there
Old Apr 8, 2009 | 11:48 AM
blkekcoupe's Avatar
yea seen this a lot, need the ecu from a 02-04, because the have different speed sensors and they are two different motors generation wise. im not sure but the cluster may also need to be swapped with the 02-04's, give a search around in clubrsx they have many people who post about the same issues of using different motor between the two platforms
Old Apr 8, 2009 | 11:51 AM
^^ And there you go. 2 people confirmed it AND you got another site that could help you out.
Old Apr 8, 2009 | 12:32 PM
simonEp3's Avatar
You put a motor from an '03 into an '06 Type S?
I'm pretty sure putting an older motor in a newer car is actually illegal...if its the same or newer its ok but other than that...it's a NOGO!!!!
Old Apr 8, 2009 | 01:08 PM
blkekcoupe's Avatar
^^hold up now that you mention it simonEP3, im wondering what motor is the OP using, base or type-s, because you cant mismatch ecu's between the base and types which im guessing he doesnt know about, blown type-s and throw in a non-types motor, THAT would be a rip-off, and you have to match the 03 type-s to the PRB ECU or the 03 base(k20a3) with a PND-A0# ecu, now for the PND make sure it is A0(5spd) not A5(automatic)
Old Apr 8, 2009 | 01:16 PM
nahonda04's Avatar
Surje.motorsports
i was also wondering this, if it was and base or an s 03 motor?
Old Apr 8, 2009 | 02:22 PM
pias's Avatar
New User
sorry,.. Type s 03 motor and type s 06 car.
Old Apr 8, 2009 | 02:53 PM
blkekcoupe's Avatar
alright so your going to need the PRB ECU, which is any from a type-s between 02-04, now your only problem you might have is the dash harness. you will either need to swap the dash harness and cluster or mess with the wiring, because the ecu pinouts are different from the 02-04 to 05-06 and the speed sensors differ between the two since vss took into affect in the 05-06.
this is just couple things i run into all the time on forums.clubrsx.com, so that my be your best bet to try so you get more of a understanding of what im and trying to explain
Old Apr 8, 2009 | 03:42 PM
nahonda04's Avatar
Surje.motorsports
^good info
Old Apr 9, 2009 | 05:24 PM
Tatmonster's Avatar
wow. shoulda just found the right motor. Isnt that what shops are paid to do? info above sounds correct. GL.
Old Apr 9, 2009 | 06:14 PM
DonReggeaton's Avatar
for you to be able to function properly and get the best out of this motor you myth want to get the 02-04 ecu because the 05-06 is a different story. motor wise and hp and all that. dealers dont know jack Sh%$.. trust me
Old Apr 10, 2009 | 06:38 AM
pias's Avatar
New User
Still an 06 trans. Swapping the harnesses and clusters isnt an option really. Im going to check into the ECU
Thanks!
Old Apr 10, 2009 | 09:34 PM
blkekcoupe's Avatar
tranny wise this is what i found on recently....
"i am not sure on the 02-04 the speed sensor is gear driven and on the 05-06 the speed sensor is magnetic pulse input so very different by all means but it will bolt up too that motor though"
petersayarath
Aug 19, 2008 03:48 PM
PhilTran.o7
Nov 16, 2006 09:52 AM
ian04rsx
Aug 2, 2005 08:08 AM
rolled.totaled
Sep 11, 2004 02:50 AM
mini-cRx
Mar 20, 2004 09:01 PM
