Dunlop Direzza Sport Z1 Star Spec vs. Nitto NT05
Has anyone compared the Dunlop Direzza Sport Z1 Star Spec and the Nitto NT05? I've read reviews about the Star Specs and they seem very promising. However, being that the NT05s just came out in February of this year (2009) there aren't that my reviews that I could find or any that compared the two tires in question. Also, these two tires are the top of line in their category in their respective companies so I figured it would be a good comparison.
Any thoughts?
Any thoughts?
No, I meant NT05. I want to stick with street tires as of right now.
I'm currently running 17x8's with 235.40.17 RT615's on my Integra. I need new tires and was thinking of going with 255.40.17's. Both tires in question come in that size so it's just a matter of which one to choose. Dry and wet traction are both important in my decision.
Also, I am aware that 17x8.5 is the minimum recommended wheel size from both manufacturers for the tire size I am considering.
That explains it.
Just by looking at the tire the Z1 is going to give you better wet traction so if you must choose by a compromise between wet and dry traction I say go with the Z1.
I know that the non-Star Specs are discontinued but the Z1's you have are Star Specs correct?
Again though, just by looking at the NT05 my guess would be they are even worse than the Azenis in the rain, especially in standing water. There is nothing in the design to dissipate water, this tire is all about dry traction, it's almost a slick.
Here's a post I've pulled up of someone who actually reviewed the NT05s after having tried them. Notice not one single mention of wet traction. Not even an attempt.. lol
http://my350z.com/forum/6763317-post10.html
Best dry traction? NT05
Best compromise? Z1
Best compromise? Z1
My understanding is that the NT05 is supposed to be a "max performance" tire (i.e. competing with the Bridgestone Potenza RE050A Pole Position) rather than an "extreme performance" tire (i.e. competing with the Bridgestone Potenza RE-11). Compared with the extreme performance tires, the max performance tires trade off some ultimate dry grip for better wet traction and longer treadlife.
But, as noted above, the NT05 isn't available in sizes smaller than 17", so it's not even worth discussing for most of us.
I've got a set NT-05's going on tomorrow in 275/40/18 for my weekend at Mid-Ohio. I'll post up here when I have some feedback
p.s. they were cheaper than RT-615's in this size by quite a bit
^^Good to know. Exactly why I said "my guess". It'd be interesting to see how this design performs in water then. I'd probably pick the NT05 in this case.
That is one of the reasons why I was considering the NT05s. They are $1 more than the RT-615s and $30 less than the Star Specs in the size I want. If their dry traction is the same as the Star Specs and can do alright in the wet the NT05s would be worth trying because of their competitive price.
In my research I've found a lot of good information/reviews about the Star Specs. I also found a Best Motoring video where they did an "Ultimate Street Tire Showdown!!", and the Star Spec's performance was comparable to the Bridgestone Potenza RE-11s. The Star Spec's posted very consistent lap times and the fastest lap overall showing that they have a wide temperature range.
As for the NT05s, I found two pretty good write-ups one in a Miata (here) forum and one on a BMW forum (here). The write-up in the Miata forum said the NT05s required more heat than the Star Specs to get going. The write-up in the beamer forum said that the NT05s didn't "chunk" at all. And both write-ups only touched on wet traction briefly.
Too bad, as some of us could run a 205/40-17 or a 225/35-17. With the current trend of larger and larger OEM wheel diameters, us older Honda owners are quickly finding ourselves without the tire selection we have been used to.
I think the NT05 will out perform the Z1 when it comes to dry grip. I'm basing my hypothesis off tire design and tread pattern only.
I had a friend tell me he did not like the NT05's as much as the dunlops. He ran Toyo R1R's on both cars he drove at Redline Time Attack and we switched to dunlops for the second session on his 135i. He wont shut up about the advan neova's though but unfortunately they are going to be expensive. I think he liked the initial grip of the R1R but favored the dunlop over it because of its longevity over the toyo. I think unless he can cough up the dough for the advans his tire of choice is the dunlop. Just a bit of food for thought. This info is coming from my friend who is a very experienced driver.
Here's one review from s2ki.com. I am not sure everyone shares the same opinion. I've seen other posts where the the Star Specs were better in the user's opinion. http://www.s2ki.com/forums/index.php...ic=674662&st=0
khronicboy420
Aug 31, 2009 09:51 PM
