Should I Take Apart My Engine?
Old Apr 8, 2009 | 08:32 AM
LSXFEIND's Avatar
Default Should I Take Apart My Engine?
hello fellas just trying to get some good advice if u would please...heres the issue i have a d15 with a y8head and y8 manifold on it ran great till one day randomly started blowing oil out of the valve cover breather also including smoke! then a day later oil started coming out of the area where the spark plugs go??? another day passes and it starts smoking out of the exhaust massivly alot of clouds???? but the funny thing is that it runs ok, but now its starting to foul out the plugs with all the oil its throwing out, i already changed the PCV valve some im guessing rings im going to do a leak down test but besides that any suggestions??? thanks for YOUR TIME!!!!
Old Apr 8, 2009 | 08:47 AM
LSXFEIND's Avatar
Default Re: Should I Take Apart My Engine?
Nobody is on right now????
Originally Posted by lsxfeind
hello fellas just trying to get some good advice if u would please...heres the issue i have a d15 with a y8head and y8 manifold on it ran great till one day randomly started blowing oil out of the valve cover breather also including smoke! Then a day later oil started coming out of the area where the spark plugs go??? Another day passes and it starts smoking out of the exhaust massivly alot of clouds???? But the funny thing is that it runs ok, but now its starting to foul out the plugs with all the oil its throwing out, i already changed the pcv valve some im guessing rings im going to do a leak down test but besides that any suggestions??? Thanks for your time!!!!
Old Apr 8, 2009 | 08:52 AM
CW-ITR's Avatar
For the oil to foul out off the plugs, the rings must be really broken. How many plugs doing this? Also, your valve seals must have been shot to hell. If it's me, I'll swap in another engine to save time and money. Nowaday, a stock EF engine can be have for $150. Swap it in is just a breeze.
Old Apr 8, 2009 | 09:03 AM
LSXFEIND's Avatar
wow that must be really bad then lol its funny how it happened so fast though i only had it running for a month?
Old Apr 8, 2009 | 09:04 AM
Dark_Teg's Avatar
I was just wondering what the alternative to taking apart your engine was.
Old Apr 8, 2009 | 09:05 AM
apekd's Avatar
That is one of the signs of valve seals. I agree with the rings. you have compression actually leaking out and making pressure build up and blowout out through the valve cover. Just go to the junkyard, you can find a whole 1.6 motor for cheap. replace the valve seals and throw that back onto a new block
Old Apr 8, 2009 | 09:08 AM
tkda's Avatar
who built the motor?
Old Apr 8, 2009 | 09:16 AM
LSXFEIND's Avatar
thats what im thinking is gonna be the best option!
Old Apr 8, 2009 | 09:17 AM
LSXFEIND's Avatar
NOT ME im guessing the person who had the engine before me!
Old Apr 8, 2009 | 09:26 AM
r4BBiT's Avatar
The problem with engine from junkyard is that you might not get lucky and there might be a lot more wrong with it than anticipated and cost you even more. I just changed my piston rings couple weeks ago on my D15B2 with MPFI swap and i it costed me $170CDN in total (not including my labour). I love it now, it doesn't take any oil anymore.
Old Apr 8, 2009 | 09:44 AM
CW-ITR's Avatar
There always someone swapping out his engine for bigger, better ones. Those are the ones you need to get a hold of.
Old Apr 8, 2009 | 09:46 AM
LSXFEIND's Avatar
I know i wish i could get a b-Series lol but too much for my lil budget ill probably just pick up a d16 short block from the junk yard
Old Apr 8, 2009 | 09:50 AM
mar778c's Avatar
Community Builder
Community Influencer
You could do a budget rebuild. If you have some mechanical skill and the helm manual, it really is easy.
Old Apr 8, 2009 | 04:15 PM
LSXFEIND's Avatar
well what do you exactly mean by budget rebuild?
Old Apr 8, 2009 | 04:25 PM
D16SiHatch's Avatar
as in just replace the important necessities. (i.e. rod/main bearings, piston rings, valve seals, hg)
Old Apr 8, 2009 | 04:41 PM
mar778c's Avatar
Community Builder
And oil and water pumps, rear main seal.
Old Apr 8, 2009 | 08:24 PM
LS-T240z's Avatar
rings
Old Apr 8, 2009 | 09:57 PM
LSXFEIND's Avatar
Anybody think its a blown head gasket by any chance that im not catching???
Old Apr 9, 2009 | 06:21 AM
ef1.8's Avatar
From everything youve described I would say no, its not just the head gasket by itself.
Oil should not be getting into the combustion chamber.
90hondaccord
May 25, 2014 10:42 PM
tomster
Aug 30, 2006 03:17 PM
Jax4gencivic
May 4, 2006 07:59 AM
preludeguy_92
Jun 25, 2005 11:39 AM
inline976
May 4, 2005 02:54 AM
