Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Do I need change ATF at 30K ? on 07 Odyssey
Old Apr 7, 2009 | 07:41 PM
hondafamily's Avatar
New User
Default Do I need change ATF at 30K ? on 07 Odyssey
My 07 Odyssey reached 30K and the dealership suggested me to do transmission service.
What would be your suggestion?
A. Leave it alone until it reaches 60K.
B. Drain out and refill new Honda ATF.
C. Have dealership pressurize out all old fluid and refill new Honda ATF.
Tks,
Tony
Old Apr 8, 2009 | 05:59 AM
pgpbubble's Avatar
Default Re: Do I need change ATF at 30K ? on 07 Odyssey
You could do it two ways, follow the maintenance minder for the service, or do it at the 30k intervals. Its all up to the owner.
Old Apr 8, 2009 | 08:22 AM
New User
pgpbubble,
Thank you.
hondafamily
Old Apr 8, 2009 | 09:51 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
drain and fill is just fine for 30k intervals... you can either do a drain and fill now or a flush later...
Old Apr 8, 2009 | 12:28 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Tks,
Tony
It's already known that Odyssey have transmission problems. I would let the dealership do C.
That is one thing I would do "more than necessary" or at least right on top of it.
Old Apr 8, 2009 | 07:27 PM
New User
Thank you all.
Old Apr 9, 2009 | 06:17 AM
pgpbubble's Avatar
I personally do not recommend the flush. Flushing the transmission breaks free particals stuck in bands which could honestly be helping your transmission. I've seen a flush actually make a transmission inop after a customer complaining of a slipping or banging into gear.
Old Apr 10, 2009 | 04:44 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
true, but on the reverse, I have seen a flushes bring trannys back from the dead!
Old Apr 12, 2009 | 07:02 AM
anngsr1's Avatar
i have 94 honda 180k, only Flushing and still running.
Old Apr 17, 2009 | 02:13 PM
rkpatt's Avatar
I usually flush them . These have weak and very expensive transmissions .Change the fluid frequently and add an external cooler whether even if you don't paln on towing . I added a cooler change mine way before the recommended interval an have fingers crossed.
dpkelly
Honda Civic (2006 - 2015)
Mar 31, 2014 03:36 AM
northtexas
10
Sep 25, 2013 09:29 PM
Birdley42008
Transmission & Drivetrain
Feb 16, 2011 04:33 PM
joekrz
14
May 8, 2007 07:09 AM
mct121
25
Nov 24, 2004 11:08 AM
