Is there a "reset" for the Profec B?
I'm told it learns the cars boosting style in order to boost quicker, so what if you move it to another car, or change the motor's setup? Is there a reset for it?
I was under the assumption that once you take the power off the unit, it will then reset itself. *Not hit the Power Button, but actually disconnect the power source from the unit!* I know someone will be confused and ask.
You sure that your not thinking of the Profec A. It has fuzzy logic which "learns".
You might wanna check out the dipswitches on the back of the unit.
[Modified by 93LSivic, 3:18 PM 8/15/2002]
I think he is making refernce to the Sharp/Mild **** on teh boost controller. Moving the **** to Sharp is supposed to allow you to fit your desired boost level faster. Let me know if I am totally wrong here Jared?
You are correct, I was under the impression that it over time allowed the car too boost slightly quicker because of learning the boost curve.
uhhhh..Profec B doesn' t learn anything...its a set it and forget it type of system...Profec A is the one that learns your driving habits.
Integra21
May 21, 2006 04:16 PM
Integra21
May 21, 2006 04:15 PM
