Got a new LS crankshaft... Grooves on oil pump journal and main seal journal?
Old Apr 7, 2009 | 05:27 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Default Got a new LS crankshaft... Grooves on oil pump journal and main seal journal?
Just picked up this LS crankshaft, but noticed these grooves- Is this an issue? it is where the oil pump seal rides, and the main seal rides:
Old Apr 7, 2009 | 05:49 PM
non-VTEC's Avatar
Default Re: Got a new LS crankshaft... Grooves on oil pump journal and main seal journal?
the lip grooves are normal. especially if the crank has allot of miles on it the seals lip will cause a slight groove in those spots.
you can have the rear main seal and oil pump seal installed a slight bit further in or out so it can ride on a fresh new surface of the crank. just make sure the surface is clean and smooth.
Old Apr 7, 2009 | 06:02 PM
nytosc's Avatar
Thanks for the info- I saw people selling something called a "microgroove" kit
Its installed by a machine shop, and creates a new surface for it to ride on- How exactly do I change the position of where the seal rides? Thanks!
Old Apr 7, 2009 | 08:24 PM
ruffrhyder's Avatar
I believe it's like a repair sleeve.
Old Apr 7, 2009 | 09:12 PM
LSR-Abuser's Avatar
Ask a engine builder for a speedy sleeve i have use them many times for this.the machine shop will do it for ya.
Boosted_CRX_507
Oct 6, 2008 05:13 PM
projectTeG
Jul 8, 2006 04:50 PM
alotawatts
Jan 13, 2005 04:32 AM
NWHybrid
Jan 23, 2004 10:19 PM
