Which aluminum?
Old Apr 7, 2009 | 05:09 PM
91sihatch's Avatar
Default Which aluminum?
So I would like to get an aluminum sheet to make a skidplate. I would still like to be able to bend it and it will need to be welded in two spots. Here are the grades of aluminum I am able to get through a local supplier. Which should I buy? I think i will be getting 3/16" unless anyone can convince me otherwise. Cost is a factor as well.
aluminum sheet - mill finish non heat treatable
1100-H14
3003-H14
5052-H32
aluminum sheet mill finish heat treatable
6061-T6
Old Apr 7, 2009 | 05:14 PM
KFMRC's Avatar
Default Re: Which aluminum?
5052
Old Apr 7, 2009 | 05:44 PM
Blown90hatcH's Avatar
Originally Posted by kfmrc
5052
+1
Old Apr 7, 2009 | 09:27 PM
Race Egr's Avatar
Originally Posted by KFMRC
5052
Old Apr 8, 2009 | 04:02 AM
91sihatch's Avatar
thanks!
Old Apr 9, 2009 | 02:40 PM
punkinbeck's Avatar
dont get 6061 it tends to break when you bend it
Old Apr 9, 2009 | 04:51 PM
totally depends on the temper, thickness and bend radius. They sell it in the 0 condition that is really soft and bends easily. You can bend the T6 temper, but it tends to crack on thin stuff or tight radii.
Old Apr 12, 2009 | 12:45 AM
awill4x4's Avatar
5052 is susceptible to tight radius cracking also, try to organise bending so that it has a good radius and also so the bends are across the rolled grain of the plate rather than along the grain.
5005 isn't available over there? it's my choice of a good middle of the range alloy for fabrication, particularly the fuel tanks we build.
Here in Oz we don't get any of the 3003 alloy which is a shame as it's ideally suited for rocker cover (valve cover for you guys) fabrication.
Regards Andrew from Oz.
uberEFtuner
Welding / Fabrication
Mar 16, 2011 01:20 PM
90Rexx
18
Jun 19, 2010 08:01 PM
hondakevin21
Jan 8, 2007 01:11 PM
ungcobob
Nov 9, 2006 02:07 PM
qksl2
Mar 11, 2005 10:21 PM
