Turbo Help
Old Apr 7, 2009 | 04:05 PM
millsd4's Avatar
Default Turbo Help
Ive got a full setup for my teg including a Garret TR0759 turbo. Im running stock internals with a higher-milage engine that does not burn any oil. Im hoping to put the turbo on and run it without blowing her up, so maybe 5-6 psi? Its got an internal wastegate so can i turn the boost down? will 10psi (current setting) blow my motor if i dont drive it like a retard?
Ive got 450cc injectors, intercooler, manifold, BOV, boost controller ect.
Old Apr 7, 2009 | 04:54 PM
Top Speed's Avatar
Default Re: Turbo Help
There is no way to say an exact power/boost level that is always safe. If tuned properly I have seen stock motors handle alot of boost.
Old Apr 7, 2009 | 05:51 PM
94_Teggy's Avatar
There may be more responses in the forced induction section
Old Apr 7, 2009 | 09:02 PM
spooledinurface's Avatar
How high of mileage are you talking about? My buddy turboed his at about 130,000 on 8psi and beat on it like no other. It wasnt till after about 2 blown turbos and a few head gaskets that his cylinder rings gave out on him at 170,000. But oh well a b18b1 motor is just $500 dollars and only takes about 3 days to put in if your slow like us.
Old Apr 7, 2009 | 10:42 PM
turboteg7's Avatar
i bought a turboed gsr and who ever owned it befor me was an idiot and had the boost cranked up so a few weeks after i bought it **** on me. so right now i have it all apart puttin new rings and head gasket in it but i did find it had fe foreged alluminum pisions in it. im runnin 7 psi its got good power and id say its pretty safe on stock interals.
Old Apr 8, 2009 | 01:18 AM
millsd4's Avatar
the internal wastegate on the turbo is set for 10 psi, is there any way i can lower it to 7? its a very small turbo, spools very fast but doesnt push much air out, maybe at 10 psi i will still be safe?
Its off a Talon, TR0759
Old Apr 8, 2009 | 04:29 AM
Schister66's Avatar
Man U FTW
Boost pressure isn't what kills engines. Power is what does the damage. On a stock D series the safe limit is 220-240whp and a B series is 300-325whp.
The best option for you is to start a new thread in the Forced Induction forum. You'll get a lot more (and a lot more helpful) answers there
0618turbocivic
Jul 10, 2006 06:24 PM
Sci_v_icI
Mar 29, 2006 01:18 PM
justinb
Jun 25, 2005 04:40 PM
MooreBoost
Aug 8, 2004 11:14 AM
SOHC_MShue
Jun 15, 2004 09:52 PM
