My BMW Drag Car
I decided to ditch my BMW drive train in favor of something different. Here is what I have gotten done so far. I hopefully will start on the cage this week. I just received the chromoly.
List of specs:
4.6 teksid Aluminum block
Manley Rods and Pistons
04 cobra crank
06 gt 3 valve heads( custom Port work)
Ford Racing Wiring harness
Competition Eng 9" rear end housing
Moser third member
More to follow
All the work done my me and Bryan at Top Speed Performance
List of specs:
04 cobra crank
Moser third member
More to follow
1- No one has ever done it that I know of
2- I have already built a turbo chevy so I feel the need to build a turbo Ford
and the main reason is because I already had the motor.
I agree that lsx powered bmw's are awesome and they fit in the engine bay alot better but I wanted to be different. Plus I needed to cause some drama with a friend of mine that is a die hard bmw fan and mustang hater
we plan to build a custom twin turbo set up on the car
There are several reasons I decided to use this motor.
The 4 valve heads are actually cheaper, you can use lincoln mk8 heads and they are really cheap. The reason I used 3 valve heads is because of the Ford Racing wiring harness
http://www.fordracingparts.com/parts...KeyField=10560
I own a fabrication and tuning shop in Greenville North Carolina called Top Speed Performance
www.topspeedparts.com
